Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 06-10-2015, 09:40 AM   #1
ERASER5
ERASER5's Avatar
grinder stand
I have seen a number of grinder type stands built from 22.5" truck rims. I also looked at Harbor Freight ones, and the grinder stand at work. These "pro built" units has considerably less foot print than the truck rim.
I have 4 stock '70 six lug drum type 15" steel rims in the garage. Do you guys think these would make a suitable base?
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 06-10-2015, 05:49 PM   #2
68c10airstream
68c10airstream's Avatar
Re: grinder stand
A friend had a grinder with a rim as it's base and i remember kicking the rim many times during use. I think it's a very good base and just a matter of getting used to it.
I had the idea years ago of using say a 13" rim and filling the underside with concrete for additional ballast!
I purchased a used baldor brand grinder and it had a baldor cast base. The base is square and i still have kicked it a few times, but it's rare.
68c10airstream is offline   Reply With Quote
Old 06-10-2015, 10:32 PM   #3
Jim53066
Jim53066's Avatar
Re: grinder stand
Better look close at the rims first, to see if they are 3 nub or 4 nub.
If 4 you can sell them for a nice chunk of change and buy a grinder and pedestal.
Jim
Jim53066 is offline   Reply With Quote
Old 06-11-2015, 07:43 AM   #4
ERASER5
ERASER5's Avatar
Re: grinder stand
Jim
Good idea. I'll check.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 07-03-2015, 12:05 PM   #5
ranger danger
ranger danger's Avatar
Re: grinder stand
Get used big rig brake drums. They are smaller diameter than the wheels and weight about double.
1969 C20 Suburban "Rez Dog"
Rebuild America one testicle at a time.
US Army 1977-1979 12B Combat Engineer
US Navy 1979-1983 Gunners Mate Guns (GMG)
NRA Life Member
Unrestrained Children in back seats cause Accidents.
Unrestrained Accidents in back seats cause Children.
ranger danger is offline   Reply With Quote
Old 07-04-2015, 08:00 PM   #6
ERASER5
ERASER5's Avatar
Re: grinder stand
Big rims would be nice, but I have these. If this does not work, I'll always wish it had.
On with the show, that doesn't really have much of a show...
The finished product. Nothing complicated, rim, 3/8" plate, 2X2-1/4" tube, Vice that has been mounted to another 3/8" plate and a receiver adapter tube welded to the bottom.
The real complication was adding 3" of 2x2 to what other 2x2 tube that was not quite long enough. After welding that, I used the oldest trick in a welder pocket, grinder and paint! My goal was to have the vise base even with the weld table. I missed by 3/8". OK, so which idiot forgot about the 3/8" plate at the top? Good help is hard to find. I blame the guy in the last pic. He was too busy doing something or other.
I still have to drill the cross bolt hole. That can wait a few days, i doubt the vise will jump up 3 inches to escape.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 07-04-2015, 08:04 PM   #7
ERASER5
ERASER5's Avatar
Re: grinder stand
I also picked up this from TSC. Clearanced for $30! Easy to put together, real easy. The lasers did need some adjustment, again real easy. At least it's a start.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 07-04-2015, 08:15 PM   #8
Willie Makeit
Willie Makeit's Avatar
Re: grinder stand
no pic, but i used a brake drum off a 3 axle dump truck. smaller diameter than the wheel but heavier.
Willie Makeit is offline   Reply With Quote
Old 07-04-2015, 08:26 PM   #9
ERASER5
ERASER5's Avatar
Re: grinder stand
I missed that opportunity about 7 years ago. The tech school was ditching a semi wheel stand. It was nice but it was "home made" so the school could no longer use it. Wierd. A school that is teaching welding, machining and fabricating could not use fabricated stuff. Lawyers Sheeesh! Spied it before class, it was gone after class. Missed it by that much.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 07-04-2015, 08:29 PM   #10
In The Ten Ring
Re: grinder stand
I'll have to build my own grinder base too but it needs to be on wheels
In The Ten Ring is offline   Reply With Quote
Old 07-05-2015, 08:52 PM   #11
ERASER5
ERASER5's Avatar
Re: grinder stand
Mine is on one wheel. Does that count?
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
