07-06-2015, 01:42 PM | #1 |
Re: Adding FI-Fuel tank. Transfer from stock tank??
I'm using both tanks as a method for storing E85 since it's not available everywhere I need to travel. I've got a small Holley pump as a transfer, and used a bulkhead fitting with a dip tube in the rear mounted cell. I do have one issue to fix; the pump on the "off" position doesn't prevent the siphon. I have just been reaching behind the seat and cracking open the fuel line momentarily. For the fix I'm thinking a nitrous fuel solenoid plumbed will do the trick.
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
