Suspension rebuild help needed..
I've had my project for many years now. Unfortunately, i took everything apart a long time ago (many years ago). I have replaced all the front suspension part with new parts (ball joints, tie rods,etc). Now i don't know where to start with putting it back together..is there a order to putting it back together? Is there some measurements that puts it close to alligned? Do i torque anything? Do i need to grease anything now? it's a 72 2wd. I have airbags so the suspension will be at different levels...i hope you can understand what i am asking here...
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
Re: Suspension rebuild help needed..
Not the cleanest job, but it really helped me when I was putting my frontend back together after replacing everything with Moog parts.
http://67-72chevytrucks.com/vboard/s...d.php?t=556867 |
Tagging for later, thanks BigMike
Where are you at now? Control arms attached? How about the spindle? Let us know where you're starting and we'll get you to the finish line!
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
