Old 06-21-2015, 05:04 PM   #1
Jimal
Jimal's Avatar
Nose to frame mount, what should be there?
Today I celebrated Father's Day by replacing the cab mounts on my truck. That project was pretty straight forward, though I do have some adjustments to make to the clutch linkage and a couple other minor things to make up for the fact that the cab sits a bit lower with the new mounts.
What I discovered during the disassembly process is that there was very little holding the nose of the truck to the frame. Both mounts have delaminated, and while the drivers side was held somewhat together by a through bolt, the only thing holding the passenger side mount on was the bolt through to the sheet metal.
What I'm discovering is, with these new cab mounts, those old nose mounts no longer line up, at least where the through bolts go. I assume the through bolts were a repair by the PO and now how they came from the factory.
All this typing and all these pictures lead to this question; what exactly should be in those mounts? The instructions for the cab mounts only mention counting and retaining shims, but the mounts themselves had some rather thick rubber bushings that no longer seem feasible with the new cab mounts.
Jimal is offline   Reply With Quote
Old 06-21-2015, 06:18 PM   #2
Uptown83
Re: Nose to frame mount, what should be there?
Are those poly mounts? I just ordered some. Yet to put them on.
Uptown83 is offline   Reply With Quote
Old 06-21-2015, 07:30 PM   #3
cru_zn_29
cru_zn_29's Avatar
this is what they look like. Removed from 66 c10 rubber goes top and bottom of core support and backed up with thick washers.
cru_zn_29 is offline   Reply With Quote
Old 06-21-2015, 09:16 PM   #4
Jimal
Jimal's Avatar
That is what was in there. The PO must have had some issues with this because there was an extra 1/4" or so rubber spacer in the front mount stacks.
Old 06-21-2015, 10:11 PM   #5
Chevy Fleetside
Chevy Fleetside's Avatar
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=12 Bottom of this page.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-22-2015, 12:19 PM   #6
Jimal
Jimal's Avatar
Originally Posted by Chevy Fleetside View Post
I looked at that before I wrote. The schematic isn't as descriptive as I was hoping. It certainly doesn't look like what I pulled from the truck.
Old 06-22-2015, 12:46 PM   #7
1963c-10
1963c-10's Avatar
Few diagrams that may help
1964 Short bed trailer
Old 06-22-2015, 01:38 PM   #8
PGSigns
PGSigns's Avatar
That part you have laying on the ground used to be spot welded to the support. The sheet metal they attach to rust out on a lot of these trucks. If you look at 1963c-10's pics you can see what the sheet metal used to look like and compare that to yours to see what is missing. Hopefully some one has a support out and can post a picture of what it looked like originally.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 06-22-2015, 01:45 PM   #9
1963c-10
1963c-10's Avatar
I'm about 99% sure I have a core support mount that I can take off my donor frame.
Old 06-22-2015, 01:49 PM   #10
Jimal
Jimal's Avatar
Jimmy
The driver's side equivalent of what I pictured laying on the ground appears to be bonded - like a motor mount - to a bracket that is riveted to the the frame. The truck is a K10, if that matters with how this stuff goes together. The bushings that were in there were thicker than what is pictured above. I think the PO was trying to do some sort of body lift, or at least tip the cab back a little bit. Probably to clear the HEI which I'm sure my firewall is not clearing right now.
Old 07-03-2015, 08:40 AM   #11
Jimal
Jimal's Avatar
My core mount kit arrived from LMC yesterday. Either something is different with how the cabs are mounted with the 4x4s, or someone installed a small body lift at some point in my truck's history. The rubber bushes are much thinner than what I removed and the bolts are much smaller.
The metal bracket on the right will be reused, and bolted back where it was.
Old 07-06-2015, 07:04 PM   #12
Jimal
Jimal's Avatar
This is what I ended up with, which works. The metal piece in the original amount above was bonded to a bracket that is riveted to the frame, like a tranny mount. This side came off completely, while the other side was sort of hanging on by a thread. I through bolted both and that seems to have solved the issue, for now at least.
Old 07-07-2015, 01:49 PM   #13
61K10
61K10's Avatar
My org old ones on my k10 where the same as the new lmc kit.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
