1970 GMC 2wd Axle Help..
hey guys, Ive got a 1970 GMC 2WD Short Step, has a GM 12 bolt, 6 lug drum, all original axle, trying to find the correct length and/or splines for the axles. looking to order a set of moser axles and differential to throw into the stock 12 bolt housing. Any info would be appreciated. Thanks in advance.
Edit: Not currently near the truck to pull the rear end apart, I am in the military and stationed elsewhere, trying to get parts and whatnot on order so when i get back to the truck i can start tearing things apart and doing more work to the truck. thanks!
"Its better to burn out than it is to rust!" '70 GMC C10 2wd. 2.02 aluminum heads. TH400 trans. 450WHP '04 Nissan 350z DD, Twin Turbo, 600whp, drag beast! |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 1970 GMC 2wd Axle Help..
There were 2 different length housings in the 1970 model year.
You will need to verify what YOU have so you can order the correct parts. Both of the '70 rearends I have are the same width as the wider 71-72 trucks 5-lug rearend. Some say you could get the same width rearend as the narrower 67-69 in the early production 1970 trucks. Too much money to guess. Early housing is 55.5" backing plate to backing plate. (67-69 early 70) The later housing is 57" backing plate to backing plate. (late 70 and 71-72)
