headers are here. Is this gonna be a problem? pic inside.
After looking at many headers including the stainless ones. I bought some hookers. They were real junk I had to send them back. warped flanges.
I ended up with HEDMAN headers. 1 5/8 with 3 in collector. These were built very well. Only problem is(and I think I may send them back) when they were ground flat at the flanges, only one tube is ground to much. I dont want future problems with leaking gaskets. I know how they square the flanges and it looks like only one got grounded down almost flat but at an angle. In the pic you can tell it has a lip on the bottom that will seal with the gasket, on the top you can see it is ground just about flat with the flange. What should i do? am I over thinking this?? return or install? ![]() ![]() ![]() |
Re: headers are here. Is this gonna be a problem? pic inside.
see here.. its ground to much.
all the other look good like this
![]() ![]() Join Date: May 2015
Maybe ground to much,, maybe not,,try putting the flange side against a really smooth flat surface such as a counter top and see how flush it fits..if it doesn't have full contact then I would def send it back.
I would send em back
At the body shop.
Dougs d310-c
" That didnt make it any newer " " Dont antique the equipment " |
I had a set like that, pull out the mig, and put some weld around all the ports, and grind it all square, I hate leaky header gaskets... They never have enough sealing surface area... Buy the best gaskets you can get and match them up...
Down side to welding on a new header is it would void any warranty claim you might have. I would contact headman..they should make it right.
I'll bet they will make it right. Just show them a picture of your straight edge across it and ask them how this got by quality control.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
![]() Join Date: Apr 2009
Typical for "Hedman" headers, seen it before....
![]() Join Date: Jul 2014
I had a bad experience with the gaskets supplied by Hedman Hedders; blowouts all over the place. My racing buddy turned me on to Remflex gaskets. Worked great and wouldn't use anything else. http://catalog.remflex.com/
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783 --Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair "Life is tough - wear a cup!" "Old Enough to Know Better - Too Young to Resist" "Junk is something you will need three weeks after you throw it away." |
contact headman, while your at it, ask for an upgrade to ceramic coat for your troubles and the delay getting your project put together.
74 Stepside"Steppin Wolf":78mm Turbo LQ4/4L80e,BTR stage 3 Truck cam,3.73 12 bolt with Detroit True-Trac Project Steppin Wolf Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=670303 My Youtube channel "Bad Luck Garage" https://www.youtube.com/channel/UCRP...XkeEPCu_HmRfuw |
In my opinion, if I spend my hard earned money on a product I expect it to be right. I wouldn't try to fix them myself. They would be on the 1st thing smoking back to where they came from.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint "Cool ain't ever cheap and cheap ain't ever cool" |
