Old 06-17-2015, 02:17 PM   #1
Bpilcher72
Bpilcher72's Avatar
Steering Column Conversion
I have a 1982 C/10 with a non tilt column, column shift automatic. I want to convert to a tilt column. I have found a tilt column out of a 1985 C/10 that has tilt, cruise, delay wipers, and high and low beam on the column also. I cannot seem to find a column with wipers in the dash without all the extras. Is it possible to put this nicer steering column in mine and make it work without having to rewire the entire truck?
Brandon.
Bpilcher72 is offline   Reply With Quote
Old 06-17-2015, 02:24 PM   #2
1774btcrew
1774btcrew's Avatar
Re: Steering Column Conversion
It is a lot of wiring. A 1979-1983 tilt column will work for you and is a direct bolt in with no wiring changes.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 06-17-2015, 02:44 PM   #3
J Knight
J Knight's Avatar
You can use the 85 column in your 82. All the plugs are independent of one another. The only thing you have to do is plug in the ignition switch and the blinkers harness. The dimmer switch, wiper switch, and cruise control can be left unused on the 85 column. Leave your current 82 wiper switch and dimmer switch plugged in and it will work fine.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 06-22-2015, 07:07 PM   #4
Bpilcher72
Bpilcher72's Avatar
thanks, im planning to try it,
I see that CLASSIC INDUSTRIES sells the pulse wiper relay switch. I wonder if I purchase that module if I can switch my wipers over to pulse wipers....anybody know if the windshield wiper motor is the same on both?
Old 06-22-2015, 08:58 PM   #5
MikeB
MikeB's Avatar
I recently bought a rebuilt 79-83 auto trans tilt column from this guy. Nice column, great support.
http://www.gmtiltsteeringcolumn.com/
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 07-08-2015, 08:04 PM   #6
SnowNeck
SnowNeck's Avatar
You just saved me big time, Thank you Sir!
1985 High Sierra step side 4x4
SnowNeck is offline   Reply With Quote
Old 07-08-2015, 09:17 PM   #7
MikeB
MikeB's Avatar
You're welcome!
I just sold my old 3-speed manual column for $145 to a guy who had the part that mine needed (the shift bowl). So I'm a happy camper with only $200 net invested in my rebuilt auto trans tilt column. Of course, I also spent $30-something on the gear indicator. Interesting the way that thing works.
Mike
