Old 07-11-2015, 12:16 AM   #1
Chevy_mud_truck
Chevy_mud_truck's Avatar
Dually wheel tubs
I've never removed the tubs from a bed once I remove the filler strip that's on inside dose that open it up to gain access to to the nuts on the studs that hold on the tubs on to the bed side
Chevy_mud_truck is offline   Reply With Quote
Old 07-11-2015, 03:39 AM   #2
trixter99
I have no time for this
trixter99's Avatar
Re: Dually wheel tubs
Yes it will give you access to the nuts on the back side of the tubs but you will probably end up spinning the studs out of the tubs. I got the tubs off and then spent a lot of time spinning the nuts off with vice grips holding the studs. Then I used Speed Grip and spun them back into the tubs afte I got done bodyworking and priming the tubs.
1986 Chevy short box ( PROJECT )
1994 Chevy Blazer lifted 6"
2009 Gmc 2500 HD
1999 Hugger orange Camaro SS
2007 BMW X5 Sport
trixter99 is offline   Reply With Quote
Old 07-11-2015, 07:50 PM   #3
Chevy_mud_truck
Thanks the old bed I took off was something that was put together from aftermarket parts they drill holes on the in side of the bed to tighten the tub bolts the bed was junk there was more bondo then fiberglass on the tubs this bed is in great shape it only has a few small dents a surfs rust I taking the bed to get blasted the only thing is the hole for gooseneck hitch looks to far forward so might have weld it up and move it back
Old 07-11-2015, 07:53 PM   #4
Chevy_mud_truck
Do all the bed have these metal brackets I don't remember seen them on other beds I looked at
Old 07-12-2015, 01:25 AM   #5
trixter99
trixter99's Avatar
I have never seen those metal tabs befor. Those tubs are also glued on as well.
2009 Gmc 2500 HD
2007 BMW X5 Sport
Old 07-12-2015, 01:29 AM   #6
Chevy_mud_truck
Yes it looks like it has a bead of seam seal around them
Old 07-15-2015, 02:35 PM   #7
Desert1957
Desert1957's Avatar
Here is a Pic of an "NOS" Dually fender.
Seam sealer around the outer edges
Desert
Desert1957 is offline   Reply With Quote
Old 07-15-2015, 09:22 PM   #8
Chevy_mud_truck
Do they have the metal tabs on the top 4 or so bolts and thanks for the help and info
Old 07-16-2015, 08:56 AM   #9
Keith Seymore
Keith Seymore's Avatar
Here's what it looks like in the service manual (1985 model year).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-16-2015, 09:03 AM   #10
Chevy_mud_truck
Thanks that help I just don't want to brake nothing if I can keep from it so I can reinstall after painting with out trying to track done parts that got broke
