Old 07-12-2015, 02:12 AM   #10
RedRoad
RedRoad's Avatar
Re: TH350 leak
I had a bad leak that was difficult to track down, it ended up being the ignition control switch on the pass side under the cooler lines. The sending unit itself was shooting fluid under pressure between the steel body and plastic center. A brass plug cured that major leak but still working on a few others. Did I mention I HATE automatics!!!
RedRoad is offline   Reply With Quote
