#26 |
![]() Join Date: Jul 2007
Re: Emissions rant.
They never question mileage. My 66 does not even have classic plates. My friend was told he needed emmissions on his 70 pickup and he told them it was classic and they did it for him . I always get 5 year plates since they are not too expensive. My 06 Duramax also has 5 year plates and has never been smogged.
#27 |
Re: Emissions rant.
As far as the tach goes you could always pick up a 30$ dollar tach at the parts store and hook up the two wires under the hood so you can sit it right in front of you while you tune the carb and then unhook it when your done. Makes a handy tool. Could prolly get one from a junk yard for 5 or ten bucks.
#28 | |
Re: Emissions rant.
#29 |
![]() Join Date: Feb 2002
Re: Emissions rant.
Back in the day I bought a Sears Volts/Dwell/Tach tester. I've gone HEI and don't use dwell but I can still use the tach. Look for something like that. You might also pick up a Vacuum Meter at the auto parts store. Use it to dial in your Idle/Mixture screws. Highest reading is best. [17'' Hg @ 700 RPM for example].
Tips on cheating the ADEQ test: 1] One yellow bottle of Heet alcohol in a fresh tank of gas. Chevron is the best. 2] New PCV valve. 3] Paper air cleaner. Somehow the K&N just oozed extra hydrocarbons. 4] Gas cap. I keep a special gas cap in a plastic bag in the glove box in case I need it for testing my '68 Stepside or the '71 Jimmy. When the test is over it goes back in the bag. 5] Rainy Day. Since it's monsoon season, try to get there when it's raining. 6] Early morning. Don't try Mondays, though. The whole work-a-day world is trying to get thru on Monday morning. 7] Twelve pack of beer to entice somebody with real carb skills. You gotta find a buddy. Good Luck
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 07-11-2015 at 06:46 AM. |
#30 | |
Re: Emissions rant.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 07-11-2015 at 06:59 AM. |
#31 |
Re: Emissions rant.
I saw a video on You Tube of a guy crushing a Prius with a surplus British tank. It was cool.
#32 | ||
Re: Emissions rant.
![]() Quote:
HC is HydroCarbons. It is UNBURNED fuel. This can occur under any of the following conditions:
CO is Carbon Monoxide. Is it PARTIALLY BURNED fuel. This can occur under any of the following conditions:
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback. The C10 and the Super Beetle run, the Fastback is just not there yet! Please visit my Super Beetle and Fastback profile on TheSamba. |
#33 |
Re: Emissions rant.
Oh sweet thanks MagmaJct. that was very informative thanks!
#34 |
Re: Emissions rant.
Can you raise the GVW on your truck... I did that to my k10 and didn't have to aircare it anymore
#35 |
Re: Emissions rant.
Smog checks piss me off too. I have a 06 Cummins that is now required to be smog checked in CA. Only problem is they don't have equipment to check smog on a diesel. They charge me $60 to lift the hood and look at the tail pipe! To add insult to injury I travel for a living and am currently working on the east coast. CA is demanding I smog the truck IN California or no tags. I am driving around with 2 month expired plates becauee of them.
71 C-20 Custom Camper California Truck |
#36 |
Re: Emissions rant.
Well, we found a vacuum leak under the AFB carb [9635S]. Weiand 8004 alloy intake -- set for spreadbore. First I tried a 2" phenolic riser. Lower end was better and smoother, but @ higher RPMs. kind of a hesitant ''chuffing.'' I had a leak. Hope 16 year old Carter Comp Series carb. isn't worn out with a warped bottom. My friend had an Offy Q-Jet base-to-squarebore adapter. Had to cut out a Q-Jet type gasket from thick gray paper.
Lower to manifold now, and leaks sealed up. Felt good driving home again. Might go for it next week. Just never on a Monday.
#37 |
Re: Emissions rant.
Colorado has exemption for '75 and earlier, with a 5 year tag. My '83 Benz has to get snogged every year- opacity (soot) test. Blows clean every time, costs $55. The snot rag at the Airtest put my '97 Benz (gas engine, w/ traction control- not 4matic) on the regular roller tester, failed me because the rear brake were smoking! The ABS & TracControl did that, the pads got cooked. Official ruling, too bad- I should have told them it had to get put on the 4WD rollers! I pointed out that it's got all that info visible from the driver's seat, but to no avail. At least the trucks don't have that headache. I wouldn't mind the smog test, if competent personnel does the testing. I asked what qualifications the manager had, he said no ASE certifications, but he was authorised to run the machinery there. WTF? As to your carburettor emissions problem- make sure your float level is correct- it'll run rich enough to mess up the test. A fresh oil change helps, too.
Posted via Mobile Device |
#38 | |
Re: Emissions rant.
Mixture vs peak power, when plotted on a graph, make a nice bell curve. Too lean, less power, any leaner and you get misfire. Too rich, less power. The ideal mixture will produce the best power. (At idle, power can be implied from RPM.) The generic procedure for adjusting the mixture on pre-computer control carbs is pretty standard. Set the idle speed as best you can. Adjust ONE mixture screw until you find the maximum RPM possible. What I wrote above makes sense as you adjust the mixture screw in and out and see what happens for yourself. Drive it in too far, RPM drops, drive it out too far, RPM drops. Find the best position for highest RPM. Repeat for the other mixture screw if it had more than one barrel. Now, reset the idle mixture. Rinse and repeat. You may wish to drive in the mixture screws 1/8th to 1/4th turn just increase your odds of passing your test. Disclaimer: The above ONLY holds true IF everything is is correct. Float level, no nozzle drip, etc... Regards, Mike P.S. Some people get good results from a vacuum gauge in place of a tachometer. I find I don't get enough resolution for that method.
#39 |
Re: Emissions rant.
Awesome thank you so much!
#40 | |
Re: Emissions rant.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
#41 |
Re: Emissions rant.
I have 5 vehicles and 1 motorcycle insured with Hagerty.
