disk brakes
I know this has been asked. I was just getting ready to order my spindles and disk kit from summit and say for 17 inch rims. mcgaughy kit#63157 is this true? thanks
Never Ending Projects
Re: disk brakes
That looks like a stock size kit. I would think 15" disc brake compatible wheels would work fine.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
![]() Join Date: Aug 2012
Re: disk brakes
I agree it looks like they "should" fit the 15" wheels. We have a vendor here that deals the same parts. He should be able to tell you for sure.
http://www.azproperformance.com/McGa...C10-63157.html
Doug Old Build Thread - 383/T56 http://www.67-72chevytrucks.com/vboa...d.php?t=540838 Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua 5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital http://67-72chevytrucks.com/vboard/s...d.php?t=778784 |
Re: disk brakes
I called McGaughys they said the kit will work. But with some 15s you ay need to use a small spacer.
Re: disk brakes
I ran that kit with a set of 15's for a few days. No problem at all.
Re: disk brakes
I have McG drop spindles and disc kit with 15X8" ralleys. The only problem was the typical LCA fouling the rim at full turn lock and this only shaved the wheel weights a little.
`63 C-10 Shortwide Roller 305 LT1 cam, Eddy 500 T5 |
