Closed Thread
Old 07-13-2015, 11:05 PM   #1301
Lugnutz65
Lugnutz65's Avatar
Re: What did you do to your truck today part III
Originally Posted by LVPhotos View Post
All the parts came with Captainfab kit. The firewall kit has a spot to drill for Wilwood and all hardware and rods came with kit.
http://www.67-72chevytrucks.com/vboa...d.php?t=362375
My apologies. You showed it just fine. It's late for me and I'm a bit tired. I glanced at the pics too quickly. Looks like a very nice setup indeed. Thanks for sharing.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 07-13-2015, 11:24 PM   #1302
blown240
blown240's Avatar
I got my torque converter lockup working and I started installing sound deadener. It's 75% done. And it goes from the step in the floor, all the way up the firewall to below the glass.
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline
Old 07-13-2015, 11:29 PM   #1303
Lugnutz65
Lugnutz65's Avatar
That picture reminds me of Jiffy Pop Popcorn. The kind you make on the electric stovetop or campfire grill. It's not gonna make popcorn inside your panel on a hot day is it? Now I'm hungry for some popcorn. LOL! Nice work!
Old 07-14-2015, 08:13 AM   #1304
HappyHooligan
HappyHooligan's Avatar
Keys are now Required and glove box stays closed!!
Lock set from LMC. Doors and Ignition keyed the same. Glove box is different but at least it closes now.
Interesting part was that the key I had would not turn ignition to Lock so that I could remove cylinder. put key from new one in and went straight to lock but then would not unlock, but was able to at least get it out and changed.
Now waiting for the rest of parts for wiper reinstall..... one piece at a time.
Hooligan
The Green Hornet
1960 Apache 10 Long Fleet - Driver and Work In Progress
The Death Star
2006 Vstar 1100 - Chopped, Bobbed, Riding the Dark Side
HappyHooligan is offline
Old 07-14-2015, 08:59 AM   #1305
robber grin
Nothing...
but I have recently buttoned up the Passenger side front fender and cowl.
I've been working on 60 hood rust repairs too.
ANYONE EVER DO LINCOLN style PUSH BUTTONS on our doors???
peace ~ rg
robber grin is offline
Old 07-14-2015, 09:08 AM   #1306
rpone605
Picked up wheel dollies so we could position the truck to give us more room to work on the cab.
Took the cab off the frame and built a table to hold the cab. Welded supports for the cab and put it on its back.
Hope to start cutting floors up today.
rpone605 is offline
Old 07-14-2015, 06:15 PM   #1307
trulordd
Pulled the front bumper and grill off the '64 c-10
trulordd is offline
Old 07-14-2015, 07:08 PM   #1308
pimpston65
pimpston65's Avatar
peek-a-boo, I see you!!!
pimpston65 is offline
Old 07-15-2015, 12:20 AM   #1309
Pappyx3!
Pappyx3!'s Avatar
Been trying to post an update since Sat. but I can't get my phone to upload the pics...
Bought a spare 250 6 cylinder, that had all the brackets, pulleys and pump to update the 66 with PS. Just need a steering gear and a mounting plate from Captainfab.
Also scored two 3 Nub wheels for free!
And finally got the 383 fired up again in the 62! got a short piece of video. Will try to upload pics and video tomorrow from my PC.
Pappyx4!
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400
1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver
John 3:16
Pappyx3! is offline
Old 07-17-2015, 12:58 AM   #1310
SnS C10
SnS C10's Avatar
Installed the procomp monster tach, procomp water temp gauge, cd stereo, and grant steering wheel. Very happy with the results over the stock look
SnS C10 is offline
Old 07-17-2015, 01:03 PM   #1311
LVPhotos
LVPhotos's Avatar
Getting closer to final fab on transmission crossmember. Sucked trying to get x and trans center with bar without going too far.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline
Old 07-17-2015, 02:10 PM   #1312
Pappyx3!
Pappyx3!'s Avatar
That's awesome... Had the same plans to do this on my 62! Looks sweet!
John 3:16
Pappyx3! is offline
Old 07-17-2015, 05:20 PM   #1313
LVPhotos
LVPhotos's Avatar
Waiting on paint to dry. So one more welded up and smoothed out.
LVPhotos is offline
Old 07-17-2015, 07:00 PM   #1314
LVPhotos
LVPhotos's Avatar
Let the paint dry and install.
LVPhotos is offline
Old 07-17-2015, 07:21 PM   #1315
Evoracer
Prepping the 10 Bolt
Evoracer is offline
Old 07-18-2015, 01:40 PM   #1316
LVPhotos
LVPhotos's Avatar
Now it's starting to look like a truck. Why would you fully polish stainless steel then put a sticker that won't come off?
LVPhotos is offline
Old 07-18-2015, 01:51 PM   #1317
The Rocknrod
Moderator
The Rocknrod's Avatar
Oh man - Rigid plastic packages you cant open and Stickers. Don't get me started.
The Rocknrod is offline
Old 07-18-2015, 04:30 PM   #1318
Got the mule to come out and play. Got the new (used) seats in, console redone, new shifter on board, then she won't start. Turns out to be bad HEI module. Luckily I had a spare, so the mule moves again. Man that shifter is sooooo smooth compared to the old no name one. I almost could go with a straight up shifter, but for now drive it and tinker with some other things like the kick panel speaker mounts. I just got a trial fit on them today. I had to trim them a bits as they are not a perfect fit for my 64.
Palf70Step is offline
Old 07-18-2015, 06:29 PM   #1319
Grizz1963
Grizz1963's Avatar
Today started slowly....... Woke at 05.45 as usual, got up, fed the cats, opened doors and made a mug of tea, then surfed the web, had my brekkie..... All the time killing time so that I could get to the garage and make noise by 08.00 (That is Nicola's rule)
Truck time had been slow the last few months with the new job, I wanted it to take precedence over everything else, as I wanted ithe new job to be a success.
Anyway, went to the garage before 08.00 and cleared up stuff, burned some wood etc.
Having cleared the garage, driveway, advertised some stuff on Facebook, including the 1940's steel trunk I had in the back of the truck before. Sold.
I then got a crisis call from Martin, as he was trying to load his old V8 engine and gearbox onto a pallet, headed for the Isle of Mann where it was going into another truck. So drove over to his place with some cargo straps, wood, hammer, nails and then got that all sorted. Back home via the hairdressers and Coop.
Then rolled out the truck onto the driveway, first time in months.
I needed to get the hood off, but it is not a one man job, due to the sheer size of it, so I called Mickey next door to give me a hand as Martin would be around later when he and Amanda had done food shopping and walking their pack of dogs.
Once the hood was off, it was the hood hinges and springs, no idea how I am gong to get the springs back on.
What did I do...???
No going back now.
Look closely at Martin's face...... Who needs friends like this?
At this point Ta2Don texted to see if I had time for a FaceTime chat....... Replied that I was digging a hole, for Martin.
Once the inner fenders were off, which necessitated removal of the radiator support frame/bracket it became clear the radiator needs replacing or recoreing. So looking for a new radiator now, then the transmission oil cooler was removed as I have a nice new one that Martin gave me for my Birthday when he bought a frame mounted one.
Loads of other bits like the radiator mounting kit, new fender bolts, rubbers, seals etc will be ordered from LMC etc.
Well, it is broken good and proper now.
Next up, clean the front suspension, engine, firewall and get it all painted up and looking good.
Parked up, never expected to go this far, and I do not think it is the end yet.
Still love my truck, and that has to be good.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 07-19-2015, 03:29 PM   #1320
Grizz1963
Grizz1963's Avatar
After a late, but good boot fair, some other chores, I got into the garage just after 1pm.
Pulled the truck forward, jacked up and put an axle stand under the chassis, then removed the front wheel and proceeded to scrape all the years of congealed sand, grease etc from all the suspension parts and chassis.
Not a hard job, but it just takes a lot of time to do right.
A long knive, along with some scrapers, screwdrivers and a steel brush brought me to the point where the next step will be cleaning the oily bits with some petrol and then some Gunk followed by a pressure cleaner.
After the afternoon cleaning the passenger side suspension up, I thought an almost typically American dinner would be a good thing.
Well, tried to post a pic of a BBQ but this one of Clem's shindig keeps replacing the BBQ pic...... A sign?
Now fed, and relaxed with Mrs Boss.... End of a good weekend.
Old 07-19-2015, 03:41 PM   #1321
Lugnutz65
Lugnutz65's Avatar
Originally Posted by Grizz1963 View Post
. . . . . . . . proceeded to scrape all the years of congealed sand, grease etc from all the suspension parts and chassis.
. . . . . . . A long knive, along with some scrapers, screwdrivers and a steel brush brought me to the point where the next step will be cleaning the oily bits with some petrol and then some Gunk followed by a pressure cleaner.
Grizz,
Here's a tip I learned from cleaning off several very greasy transmissions. A brush tends to smear the grease around like a toothpaste and toothbrush. So, first get the large clods of grease off with a putty knife or other tool. Then sprinkle some baking soda or flour over the entire area you want to get cleaner. The baking soda (or flour) will cling to the grease. Then use a wire brush. The flour (or baking soda) will make the grease come off in clumps instead of smearing all over the place. Add more flour as needed and repeat. Then use soap and water and a pressure washer to finish up. It's economical, environmentally safe and non-toxic too.
Old 07-19-2015, 03:55 PM   #1322
SIR
SIR
SIR's Avatar
wash...wax.....rub rub rub!!! Gett'in ready for "back to the fifty's" next weekend....party time in grants pass !!!
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline
Old 07-19-2015, 04:07 PM   #1323
TJ's Chevy
TJ's Chevy's Avatar
Hope to be there with ya!
TJ's Chevy is offline
Old 07-19-2015, 05:48 PM   #1324
Grizz1963
Grizz1963's Avatar
Originally Posted by Lugnutz65 View Post
Grizz,
Thanks Jay !!
Every day is a school day, I was using the dry dusty sand over the wetter grease and oil, but the flour or baking soda sounds a lot easier.
Old 07-19-2015, 05:51 PM   #1325
I agree. Never heard of that one, but it is worth trying.
Closed Thread
