Old 07-13-2015, 06:19 PM   #751
McStuffin
Re: Slosh Tubz SEMA 2015 Build "BOOSTED BERTHA"
Originally Posted by 67cheby View Post
I guess I haven't got that far..... You can't lock it ?
No, using the EZ latch makes the interior handle (to lock by pushing forward) non functioning. Only 'workaround' I've heard is when you order the latch, request the latch to have a locking provision... basically an extra mounting tab. That way, you can attach a power door lock rod to actuate the lock from the interior... Can anyone confirm that when using the stock exterior handle, the exterior lock (with key) functions fine?
Awesome build by the way, will be looking for it at SEMA... which booth?
McStuffin is offline   Reply With Quote
Old 07-13-2015, 06:21 PM   #752
67cheby
67cheby
67cheby's Avatar
Hmmm... I will email and ask them . Precision Replacement Parts booth #24575 right off of the side of the GM Booth
67cheby is offline   Reply With Quote
Old 07-14-2015, 09:28 AM   #753
67cheby
67cheby
67cheby's Avatar
ok here comes a ton of updates !
Lets start with more progress on the shaved drip rail, front and rear almost completely done . I am still working on the sides I am giving them just a little lip that hangs over the edge of the door so they will have just a little something to detour the rain from the door gaps.
Finally finished up the welding on the firewall panels
Old 07-14-2015, 09:32 AM   #754
67cheby
67cheby
67cheby's Avatar
Then I did a quick "zip tie" test fit on the custom Flex-a-lite radiator this baby is HUGE and TOP NOTCH !
Mocked up the CPP rack in the Porterbuilt suspension
Started hanging the Flowmaster 40 series mufflers with our custom built mounts. The exhaust will be 3 inch stainless tubing from Flowmaster
Old 07-14-2015, 09:47 AM   #755
CTurner1978
It is true. The Altman Easy Latch does not allow you to lock the latches by the old method of pushing your handle forward. Upon request, we can add a locking feature on the bottom of the latches (at no extra charge) that will give you a place to hook up a lock actuator or if you decide to fabricate some type of locking mechanism. We have gone back and forth on the issue and we know the only real way to approach it is to design a push-pull cable locking system for each vehicle that we design latches for. It may be something we look at in the future, but we just aren't working on it at the moment.
All Altman Easy Latch kits work with the exterior locks. On the this particular kit of course, the lock is in the button, so it really has nothing to do with the latch.
Mike, I should have asked you if you would be running power locks. Let me know, and I will get you some locks sent over if you need them.
www.triquemfg.com
CTurner1978 is offline   Reply With Quote
Old 07-14-2015, 09:55 AM   #756
67cheby
67cheby
67cheby's Avatar
Awesome, Thanks Chris ! Yes we will be running power locks .
Old 07-14-2015, 11:52 AM   #757
watahyahknow
watahyahknow's Avatar
firewalfirewall looks great think thats one of the things i will buy when i start on my own truck : a beadroller
there so many thing you just can make look better with one of those
prolly buy a few of those hole punch/flangers too
i like the hangingsytem for the exhaust too but i wonder if the rubber insulators are big enough and if they hold up when they get hot
might do sumtin simulair but mount the whole exhaust allmost solid (with room to expand) and use flex couplings right after the headers , those should stop any vibrations comming from the engine transfering to the chassis
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 07-14-2015, 12:12 PM   #758
67cheby
67cheby
67cheby's Avatar
The isolators are exhaust hanger grommets so hopefully they will take the heat
Old 07-14-2015, 01:53 PM   #759
K5 Addiction
K5 Addiction's Avatar
I'd love to know what you figure out on this. I will need to run power locks as well. I did the altman latch and Kindigit door handles so trying to figure out the best way to lock the doors.
K5 Addiction is offline   Reply With Quote
Old 07-14-2015, 06:04 PM   #760
jlsanborn
jlsanborn's Avatar
Muff mounts look awesome man! Where you headed with tailpipe?
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 07-14-2015, 06:20 PM   #761
67cheby
67cheby
67cheby's Avatar
that my friend is a great question.....I wish I knew the answer myself !
Old 07-14-2015, 07:22 PM   #762
joe dirt
joe dirt's Avatar
drip rails look great!..i did that on my old 69 c10 and was amazed how much work it took...I think I was into the rails for almost a month...but worth it when is was done
1961 c10 longbed - gone
1964 c10 swb
joe dirt is offline   Reply With Quote
Old 07-15-2015, 10:17 AM   #763
67cheby
67cheby
67cheby's Avatar
I am about 12 hours in and I figure I have about 4 more hours to go, I am digging the look !
Old 07-15-2015, 10:20 AM   #764
67cheby
67cheby
67cheby's Avatar
welding up more gaps....
Old 07-15-2015, 10:24 AM   #765
67cheby
67cheby
67cheby's Avatar
Finally test fitted the rear Budnik Pivot wheels.....man I am in LOVE with this wheel ! 22x10.5 with 6 inch back space. It looks like we are going to narrow the rearend about 2 inches on each side. They are wrapped in Pirelli Pzero Nero's 315-25-22's
Old 07-15-2015, 10:47 AM   #766
TypeSL2
Those wheels look amazing. Perfect style for this old truck. And damn that is some meat.
James
TypeSL2 is offline   Reply With Quote
Old 07-15-2015, 12:02 PM   #767
clemdaddy
clemdaddy's Avatar
wow, whats not to love about those wheels. even though they're a modern size they got an old school feel about them. good choice, well worth narrowing the rear.
good work on filling the seams too...
clemdaddy is offline   Reply With Quote
Old 07-15-2015, 12:11 PM   #768
tinydb84
tinydb84's Avatar
Any thoughts on using a tig with silicon bronze for the gaps? I want to do something similar with my 66 (whenever I get to it) but the thought of that many tacks is making me think that the gaps aren't that bad hahah
David
Instagram: myfabguy
Old 07-15-2015, 12:23 PM   #769
watahyahknow
i've heared about someone else that tacked normal gas weldingrod to the end of the doors with a migwelder and then shave them to size the gap could use realy thin roundbar too same thickness as the folded part of the doorskin
seems to me its a bit eazier for someone not too experianced with gaswelding using bronze
Old 07-15-2015, 12:36 PM   #770
67cheby
67cheby
67cheby's Avatar
James
thanks !
Thanks Clem, I need to get with you soon !
someday....yes I want to get a tig and learn to use one !
I used the round bar on the top and front edges of the door also
Old 07-15-2015, 02:15 PM   #771
Rod Stryker
love the wheels, are you narrowing it because the wheels won't fit when the bed is on?
Rod Stryker is offline   Reply With Quote
Old 07-15-2015, 03:06 PM   #772
67cheby
67cheby
67cheby's Avatar
Correct ! Thank you !
Old 07-15-2015, 03:46 PM   #773
Rod Stryker
well, crap, Im looking at 22x10.5's with a 6-15/16" backspacing and was hoping they'd fit
Old 07-15-2015, 04:01 PM   #774
69short
69short's Avatar
Those wheels look great. Love the truck
69short is offline   Reply With Quote
Old 07-15-2015, 05:00 PM   #775
Grizz1963
Grizz1963's Avatar
Wheels can do with a thread of their own.
These really are very special.
I love them.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
