Old 07-12-2015, 10:56 PM   #1
gmcbigbl
gmcbigbl's Avatar
Factory Options on 1961 Apache 3/4 ton???
1961 3/4 fleet has generator and oil pressure gauges. Normally see the idiot lights and Don't ever see these. Are they factory????
Also has the emergency brake handle on the floor (driveshaft) next to 4 speed shifter???? I've had other 3/4 ton Chevy trucks (2 and were 1966)
and handles were under steering wheel with cables for rear drums.
Anybody know what's up. It is a 3/4 with vin # 1C2540107771 Anybody know where it was made?
gmcbigbl is offline   Reply With Quote
Old 07-12-2015, 11:01 PM   #2
blown240
blown240's Avatar
Re: Factory Options on 1961 Apache 3/4 ton???
Looks like it has windshield washers and the upgraded heater.
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 07-13-2015, 09:36 AM   #3
1963c-10
1963c-10's Avatar
The gauges were added by someone else. Not factory option on that cluster. The factory did have a full gauge cluster available, but that's a warning light system that someone has modified.
1964 Short bed trailer
Old 07-13-2015, 10:01 AM   #4
MitchFloyd
MitchFloyd's Avatar
The "O" designates that it was manufactured at the Tarryton, NY plant. Also, most likely the E-hand brake was added or altered later. They were on the 1 tons and heavier trucks.
'62 Chevy K10
MitchFloyd is offline   Reply With Quote
Old 07-13-2015, 10:02 AM   #5
TJ's Chevy
TJ's Chevy's Avatar
Neat truck!
Old 07-13-2015, 10:06 AM   #6
1963c-10
1963c-10's Avatar
Interesting that it has the positraction plate on the dash. Normally they are found the back of the cab behind the seat.
Old 07-13-2015, 01:08 PM   #7
63burban
Chevy addict
Cool truck, hazard flashers, windshield washers, deluxe heater, deluxe seat, someone added the gauges but looks like a nice job, throttle control and yes that is the correct E brake for that truck. Wonder what the switch under the dash is for? I dig the aftermarket side reflectors from the late 60s early 70s.
The aftermarket radio looks good to, not a hack job. Where in WI are you located?
Very nice truck
63burban is offline   Reply With Quote
Old 07-13-2015, 01:09 PM   #8
1963c-10
1963c-10's Avatar
Can you post some more pics of the seat? We're always looking for them for our custom comfort seat thread.
Old 07-13-2015, 02:40 PM   #9
gmcbigbl
gmcbigbl's Avatar
1961 Apache Came from the estate of the 94 year old original owner
who was a millright at Stokley Van Camp canning co..in Stanwood Wa.
Had a camper on it most of its life and mostly shedded.
Story is truck Rolled down hill & hit a tree, damaged Hood and fender?
Reason it has wrong hood
Truck spent entire life in the state of Washington, so seems strange
it was originally manufactured at the Tarryton, NY plant.
Checked back of the cab behind the seat and sure enough, four holes where the
positraction plate originally was.
Original owner was a real putzer. He made up at least four shelves around inside of cab.
Check out the Allstate fire extinguisher and holder by drivers post!
Cut a side entrance to box on passenger side???
Old 07-13-2015, 08:08 PM   #10
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Did a nice mod on the Fleetside access door using a original dispatch box lock. Is there a ring on the wood floor for a propane bottle?
Old 07-13-2015, 08:51 PM   #11
jdl71
jdl71's Avatar
Good catch, is that something you've seen before? I would not have noticed that had you not mentioned, but I do think I see the ring right underneath the access door. I assume it was for filling the tank?
To the OP, sweet truck. Hemmings Muscle Machines, which I read religiously, calls the putzer's add ons Day 2 mods. As in stuff that would have been added after it came home from the dealership.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 07-14-2015, 01:35 PM   #12
61K10
61K10's Avatar
being an 0 in the vin i would say it was built at the Oakland plant in ca.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 07-14-2015, 04:11 PM   #13
tkeduk8r
tkeduk8r's Avatar
I have a 63 3/4 2wd that has that parking brake as well
... It also has 15 in 8 lug wheels too.... So I think that parking brake is factory not an add on ( although, like anything else, it could have been changed over)..
Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
