Old 02-11-2004, 04:29 PM   #1
67chevemall
67chevemall's Avatar
Carb cleaner for rebuild?
What do you guys use to clean the carb out for rebuild?
I have my rebuild kit and have taken everything off the carb, but now I'm stuck as to how to clean the thing so it is brand new!
I guess I'll need compressed air as well to blow out the small holes??
Any thoughts??
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 02-11-2004, 04:38 PM   #2
fatfords
fatfords's Avatar
I use the Berryman's B-9 (I think) in the gallon can with the parts basket inside. If I remember correctly, the quadrajet will not fit inside the can, so you have to soak one end of the body and then turn it and soak the other. Then blow it out with compressed air (wear goggles) and do "spot cleaning" with B-12 or lacquer thinner.
That works pretty well for me. Good Luck!
'56 F-100 (w/all GM stuff)
Lookin' for another parts chaser!
'05 GMC crew cab
fatfords is offline   Reply With Quote
Old 02-11-2004, 04:42 PM   #3
Short-Fuse 72'
Same here. Berryman's B-12.
Ya'll hear that? We's usin' codenames.
Short-Fuse 72' is offline   Reply With Quote
Old 02-11-2004, 04:50 PM   #4
COBALT
COBALT's Avatar
I went to a restaurant store and got one of those metal food pans deep and wide enough to hold everything. Then I got one the exact same size that was perforated. Once everything is stripped down (and you've removed all of the plastic and rubber parts) I use a gallon of carb parts cleaner you get from NAPA. Sometimes it requires two cans because the pan is larger.
Then I let it soak for 24 hours. Then I scrub them with a light metal brush. I use NAPA brake cleaner, scotch brite, and compressed air to finish them off before I start assembling everything. Works great.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 02-11-2004, 04:54 PM   #5
69sixpackbee
Xylene!
Wear rubber gloves unless you want your liver to turn into a sponge
69sixpackbee is offline   Reply With Quote
Old 02-11-2004, 05:25 PM   #6
67chevemall
So drown it in a pool of cleaner for 24 hours in a big enough pan!
Then spot clean and blow out with air!
Wear safty glasses and gloves.
Any thing I missed?
Thanks a million you guys are the best!
Old 02-11-2004, 06:48 PM   #7
jhow66
jhow66's Avatar
yea-make sure you remember how to put it back together. lol
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 02-11-2004, 07:48 PM   #8
Short-Fuse 72'
That's always an important step.
Old 02-11-2004, 07:55 PM   #9
charles oliver
68 camtruck
charles oliver's Avatar
Carb Cleaning
Take a couple digital pics, Only If your memory is like mine. LOL
71 GMC Jimmy 4X4
68 Huger Orange Camaro 454 with TH400 :gmc
charles oliver is offline   Reply With Quote
Old 02-11-2004, 08:33 PM   #10
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Make sure you wear disposeable clothing and be prepared to wear the smell for about 3 days. That stuff (Berrymans B-12 in the gallon can) is nasty.
67Fleetsidedream is offline   Reply With Quote
Old 02-11-2004, 09:04 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I agree with everything said...esp the part of smelling like the B-12 chemtool. That stuff STINKS.
Expect the wife to make you sleep on the couch.
Old 02-12-2004, 10:47 AM   #12
67chevemall
I'll have to see if they seel that Berryman's in
As for the couch! Man I have a stiff neck!LOL
Maybe wait for the nice weather and do it out side!
Old 02-14-2004, 05:14 AM   #13
1972C10
1972C10's Avatar
Most of the time unless there ungodly nasty inside you can get away with just aresol carb cleaner.
1972C10 is offline   Reply With Quote
Old 02-14-2004, 05:46 AM   #14
68LSS1
68LSS1's Avatar
I also agree with everything everyone else said. One thing that I use to make it easier for soaking the body is a ammo box. If you live around any bases or have any surplus stores around you can get them real cheap. Occasionally you'll get one that will leak but a quick weld or some JB Weld will make it all good. Plus you got a lid to keep the fumes down.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 02-14-2004, 11:01 AM   #15
Blue Beard
Blue Beard's Avatar
Never heard of Berryman's.......
Where is it available.........?
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-14-2004, 12:40 PM   #16
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I also use berryman's b-12 work damn good.. Blue beard I usally get mine at the local part's house in the chemical isle..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
