Old 07-16-2015, 04:28 PM   #13
Blessed66
Blessed66's Avatar
Re: Engine gets hot at idle
Originally Posted by burkeftm View Post
Another thing to check is ,does your truck have a heat riser (spring or vac operated flap) between the r side exhaust manifold and the exhaust pipe. I had one with the same symptoms as you described ,driving temp would be ok ,idle at traffic light mine would go above 230 if I let it idle long enough it would boil over. The flap was seized in the closed position, Bob
Oh, that's a good one! I didn't think of this. Half the reason why I'm using headers in my other thread (not trying to threadjack or promote). It can mimic the same symptom as a plugging converter you had mentioned (Dannyboy) which includes overheating due to trapped exhaust gasses.
Current Projects:
1984 GMC, LWB Fleetside, 305/350 - Currently Doing TBI Conversion
1966 GMC, SWB Stepside, 350/200-4R - Currently waiting patiently.
Blessed66 is offline   Reply With Quote
engine, hot idle, temp high
