Old 11-14-2012, 09:33 AM   #1
LDO
LDO's Avatar
Glove box question
Maybe a silly question but I was wondering, is there a spring or something that 'pushes' the glove box door open after you hit the latch button?
The button on my 66 unlatches fine but I have to dig my finger into the side to open the door. If I adjust the latch to make it easier to open the door, it rattles when closed.
Just curious...
LDO is offline   Reply With Quote
Old 11-14-2012, 10:42 AM   #2
1963c-10
1963c-10's Avatar
Re: Glove box question
There are two little rubber bumpers that give it a little "spring"....also keeps the glovebox door from ratteling. I replaced my dry rotted ones and the door opens easier. There is no spring assembly that helps open it though. The lock kinda acts like a spring to open it. You might check the condition of the rubber bumpers...they are still produced and maybe adjust the latch a little.
1964 Short bed trailer
Old 11-14-2012, 11:42 AM   #3
LDO
LDO's Avatar
^^ thank you sir!
Old 11-14-2012, 01:58 PM   #4
Hx16457
Hx16457's Avatar
1963-C10 is 100% correct! Also if you install the Glove box Light it too has a spring loaded switch that also pushes the door open!
People who make excuses didn't want to do it in the first place!
http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16
Hx16457 is offline   Reply With Quote
Old 11-14-2012, 02:09 PM   #5
1963c-10
1963c-10's Avatar
Yes....and they are easy to install. Just plug & play
Old 11-14-2012, 04:34 PM   #6
ChuckW
ChuckW's Avatar
Yes. There is a small spring located on the bottom center of the glovebox door. It just snaps into place. 66C10.
ChuckW is offline   Reply With Quote
Old 11-14-2012, 06:01 PM   #7
1963c-10
1963c-10's Avatar
Was that for 60-66 or just 64-66. I have never seen a spring in a 60-63 glove box door. Im not saying there isn't one, I've just never seen one and Ive taken a few out/apart.
Old 11-14-2012, 06:26 PM   #8
LDO
LDO's Avatar
tell me more about this spring? any pictures?
Old 11-14-2012, 07:27 PM   #9
64fleetside
64-66 use a small spring at the bottom center, it catches the bottom lip of the dash.
64fleetside is offline   Reply With Quote
Old 11-14-2012, 08:49 PM   #10
ChuckW
ChuckW's Avatar
I did not take any pic's when I installed.... I'll look at my LMC cat.... It's just a small piece of spring steel that has a curve to it. It just snap into the glove box door....
Old 11-14-2012, 08:52 PM   #11
63sbssbbw
UCA63
63sbssbbw's Avatar
The 60-63 chevies had a raised pivot point.
push button and push lower part of door
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 11-14-2012, 09:04 PM   #12
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I push the button with one finger and my thumb is pushing on the bottom of the door.. That seams to work too! my little bumpers have no spring left in them.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 11-15-2012, 12:57 AM   #13
Captainfab
60-66 Nut
The '60-'63's also had the little flat spring on the lower edge of the glove box door.
Old 11-15-2012, 07:10 AM   #14
Hx16457
Hx16457's Avatar
The lower center spring looks like a clip, not like a traditional " spring ", I had forgotten about that even being there.
Old 11-15-2012, 09:59 AM   #15
1963c-10
1963c-10's Avatar
Ahh...ok, now that Ive seen. Never really thought of it being a spring.
Old 11-16-2012, 12:28 AM   #16
donthekawguy
donthekawguy's Avatar
I replaced the little rubber bumpers and it didn't help with mine. I think I need one of them there springy things.
66 shorty
donthekawguy is offline   Reply With Quote
Old 07-18-2015, 01:45 PM   #17
The Rocknrod
Moderator
The Rocknrod's Avatar
There are a set of bumpers at the lower hinges also. The door sits against them when open.
Old 07-18-2015, 03:02 PM   #18
racecougar
racecougar's Avatar
The spring at the bottom of the glove box door can be seen in this photo:
Edit: Just noticed that this was a thread from 2012 that was bumped back to the top.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 12-31-2018, 07:05 PM   #19
The Rocknrod
Moderator
So anyone have a picture of the spring?
edit - Oh, GMC...
