Old 02-13-2004, 09:18 PM   #1
dtlilly
dtlilly's Avatar
Step Side Bed Questions, Please Help!
Background:
I have (2) 9 foot long step side beds complete. I want to disassemble both of them and use the best parts to make one good 9 Foot step bed.
Problem:
The steps and fenders use a 1/2" nut on the backside of a philips headed carrage bolt. As soon as I get the nut turning, the whole carrage bolt turns too. I am doing this alone, so I can't get someone to hold the carrage bolt with a philips, and even if I did have help, I doubt anyone could hold the philips screwdriver in the slots, while I'm trying to get off the rusted nuts.
I do not want to damage anything here. I have a cutting torch, but I'm scared the heat will mess up the flanges. I am also worried I might cut through the part rendering it junk in my eyes.
Any ideas?
dtlilly is offline   Reply With Quote
Old 02-13-2004, 09:39 PM   #2
72MARIO
72MARIO's Avatar
Just tighten them and break them. It's the only way I know.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-13-2004, 09:47 PM   #3
cheyenne10
cheyenne10's Avatar
sacrifice the bolt
Tack weld a nut on the phillips head, heat the whole thing or lube it overnight and put a little air ratchet torque to it.
Bob
cheyenne10 is offline   Reply With Quote
Old 02-13-2004, 10:38 PM   #4
dtlilly
dtlilly's Avatar
Dang, I was afraid I was going to get those answers. Cheyenne10, no welder...Well, I guess it's busted knuckles for me. I better get the new motor installed before I'm disabled, haha. Thanks guys.
Old 02-13-2004, 11:33 PM   #5
krue
Designated A-hole!
krue's Avatar
Don, you could try what I did. I lubed everything up with PB Blaster, then I hung my wrench on the nut and using a #3 Phillips screw driver to put the wrench in a bind. Then I used vice grips to turn the piss out of them. I may have been lucky but they all came off.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 02-14-2004, 12:07 AM   #6
You'll still be sacrificing the nut/bolt, but I turned my bed upside down and used a cutting wheel on my grinder and cut the nuts off from the underside of the bed. A couple I used my dremel tool becuase I was out of pratice using a grinding wheel that way and I had run out of cutting wheels for the grinder. You may end up having to cut the rod supports too if you want them off. I left mine attached to the fenders, but was able to work the other side off except the one that goes into the frame. I had to cut it as well. I'm just goting to weld a bolt on the end whenever I reassemble them or fab something to get it back on.
Old 02-14-2004, 12:16 AM   #7
stllookn
Saving 1 truck at a time!
stllookn's Avatar
I used a torch on mine when it was upside down and it worked pretty well. I just kept a wet towel to put out the fire in the undercoating and rotten wood. It really stinks the place up. I had to replace the wood anyway. The big angle grinder is a good idea...I have used them before too. You might get a nut breaker and try that but I am sure you tire of it and go with the torch. You are going to want to replace them all with stainless anyway...LOL!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 02-14-2004, 11:32 AM   #8
dtlilly
dtlilly's Avatar
Thanks for the responces. I guess the bed needs to come off the truck so I'm not laying on my back in the mud. I'll try to find a ratchet with a real long handle and just try to muscle these fenders and steps off.
I learned a trick taking apart the short step bed (already had fenders and steps off). I removed all the wood. Then I was able to put a vice grips on the bolt and turn it off with a socket. To get all the square nuts off the bed strips, I used the vice grips again, then turned them off using a 7/16 open end wrench standing on end, and another smaller open end wrench to turn the 7/16th. Took awhile, but no damage to anything...including knuckles.
Old 02-14-2004, 03:22 PM   #9
68LSS1
68LSS1's Avatar
If your not worried about saving the bolts it's very easy to drill the head of the screw off just like you were driling a rivet off.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 02-14-2004, 06:55 PM   #10
Stroker
I used the drilling method posted by 68LSS1.
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
