Old 07-20-2015, 10:46 AM   #1
YOLO
Custom Truck Lover!
YOLO's Avatar
Need parts help for power steering conversion
I bought CaptFab's adapter plate. I know I need 73+ gear box and pitman arm. I will be using an A/C compressor too. My question is what is the correct pulley configuration for the 350 sbc set up? If you know, please be exact. Pictures would be great too. Thank you ahead of time.
Squarebody guy
YOLO is offline   Reply With Quote
Old 07-20-2015, 07:18 PM   #2
YOLO
Custom Truck Lover!
YOLO's Avatar
Re: Need parts help for power steering conversion
anyone???
Squarebody guy
Old 07-20-2015, 07:40 PM   #3
l79m20
What engine are you working with?
l79m20 is offline   Reply With Quote
Old 07-20-2015, 10:07 PM   #4
YOLO
Custom Truck Lover!
YOLO's Avatar
350 out of a 70 Camaro
Old 07-21-2015, 01:22 AM   #5
Captainfab
60-66 Nut
If you are still using the long water pump that came in the Camaro, then to simplify it you will need pulleys and AC brackets for a '70 Camaro. I'm not sure if the pulleys on the Camaro engine will have the extra groove for the AC belt. Maybe if you post pics of what you have, it will be easier to help.
Old 07-21-2015, 10:00 AM   #6
vince1
I took the box with Pitman arm and shaft from a 67 and it worked OK, along with the bracket modification.
For the pulley set up probably the easiest might be to cruise the junkyards to find a compatible part.
vince1 is offline   Reply With Quote
Old 07-21-2015, 10:54 AM   #7
YOLO
Custom Truck Lover!
YOLO's Avatar
Here are pictures of the 350 sbc in the 70 Camaro
Name:  2015-07-21 07.37.18.jpg
Name:  2015-07-21 07.37.22.jpg
Name:  2015-07-21 07.37.37.jpg
Name:  2015-07-21 07.37.50.jpg
Name:  2015-07-21 07.38.52.jpg
Squarebody guy
Old 07-21-2015, 10:57 AM   #8
YOLO
Custom Truck Lover!
YOLO's Avatar
Im ready to stab in the motor and trans.
Name:  2015-07-21 07.39.24.jpg
Squarebody guy
Old 07-21-2015, 11:18 PM   #9
YOLO
Custom Truck Lover!
YOLO's Avatar
Can anyone look at my pictures and just tell me if I need to use all 70 Camaro pulley system? I know if will use a 73+ gear box and pitman arm.
Squarebody guy
Old 07-22-2015, 12:41 AM   #10
padresag
If it worked in the camero it will all work in your truck. except that that the fan location will not be right if you decide to run a stock type shroud. use the 73 p/s box and pitman arm
ron
padresag is offline   Reply With Quote
Old 07-22-2015, 01:04 AM   #11
Captainfab
60-66 Nut
There's no reason the '70 Camaro PS pump and even an A/C compressor and it's brackets won't work. To add A/C you will need a different water pump pulley and possibly a crank pulley. I'm really not sure on the pulley needs for A/C on a long water pump small block.
In case you do not know, all trucks '72 and earlier originally came with short water pumps. Consequently certain factory application parts will not work quite right. You will also have to move your alternator wiring to the passenger side.
