07-20-2015, 11:14 PM | #1 |
lowering help
I'd like to drop my 77 C10 4" in front and 6" in back. Will this require a flip kit, and if so do i need new parts to do that? to drop the front, what should i do and what parts should I get?
thanks |
07-20-2015, 11:23 PM | #2 |
Re: lowering help
Spindles, coil springs, flip kit and shackles if not low enough.
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
07-21-2015, 09:24 AM | #3 | |||
Re: lowering help
Same companies for drop springs or you can cut 1-coil off the current units if you're okay w/the current ride & the truck sits relatively even (measure before starting anything). Add some good quality shocks. Once again... I highly recommend measuring all 4 corners on a level surface & record it down in a notebook before starting.
07-21-2015, 01:02 PM | #4 |
driving is in my blood
Re: lowering help
Flip kits don't come with shock extenders, at least not the western chassie kits I've bought in the past.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
07-21-2015, 01:26 PM | #5 | |
Re: lowering help
I would recommend buying them then since they don't come w/the kits.
