07-10-2015, 10:33 PM | #1 |
falls in its face and pops through intake...fixed
After I put my cam in the truck would run but when you would stomp it, it would hesitate fall on its face and every once in a while pop back through the intake. It also smoked white all indications of running lean. So I had the tune checked they said it was good (mail order) then I also reconfigured the intake and mass meter. Then added a fuel gauge. I had 58 psi it did not seem to lose much when I reved it but did fall some when I would hit it hard and nearly die. I was really leaning towards the tune being off because the psi seemed good. We then I find a guy with a camaro pump fairly new that had totaled his car. I picked it up for 50$ and removed the regulator out of it. I dropped it in tonight and wow. It's snappy now can't wai to boil the meats off! I looked all over for answers with no luck so I'm posting this for those with the same issue. It's probably a week pump
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
07-19-2015, 12:35 PM | #2 |
Re: falls in its face and pops through intake...fixed
What pump did you start with?
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
07-21-2015, 01:39 PM | #3 |
I had a Silverado pump assembly in the camaro tank .I guess it was weak
