Old 05-18-2015, 02:01 PM   #1
msg
Back panel of bed sandblasting question
On the back panel of my 66 the top portion rolls over and is spot welded. I dont think that the blaster I am going to take it to has any special technique or tools to deal with, he might. If there isnt some kind of an attachment that he uses to thouroughly blast that inner folded over loop at the top whats the best thing to do? Drill out spot welds and pull it up enough so the blaster gets all the rust out?
Here is what it looks like
msg is offline   Reply With Quote
Old 05-18-2015, 02:06 PM   #2
Clyde65
Clyde65's Avatar
Re: Back panel of bed sandblasting question
just buy a new repop. by the time you blast it, you could buy a repop.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-18-2015, 11:53 PM   #3
Captainfab
60-66 Nut
As long as that panel isn't rusted thru or beat up badly, keep your original. It shouldn't cost you more than $20-30 to have that blasted.
I wouldn't mess with that top rolled edge. If your blaster knows what he is doing he can just put the nozzle up to the end of the opening on both ends and blow some abrasive thru that tube. It won't be as clean as if there was better access, but that area should be fine. You can get creative with spraying or using other methods to get some primer in there. You could also use some POR15 in there too.
Old 07-22-2015, 09:48 AM   #4
msg
The blaster had agreed to a price for the entire truck and said bringing in groups of parts at a time was fine. So they gave the front panel a shot and the top roll part looks to be more than I can take on. Thinking to coat the panel with Ospho and store it for swap meet material. Dont know what a fair price for a panel like this is. A repop is around 140 plus shipping.
Old 07-22-2015, 09:08 PM   #5
dougf
dougf's Avatar
What's your plans for the whole truck? If it were me, I would fill with some light body filler, then prime until I either found better or decided on it. If done properly it should be just fine forever. If a total resto is the goal I would just replace and get what I could for it at a swap meet like you said. If it's a fauxtina driver, maybe consider above
dougf is offline   Reply With Quote
Old 07-23-2015, 09:03 AM   #6
msg
Going for a first time total resto, so I think as much as I hate to spend the $ the time and frustration for repair that may be worth it. If they had a patch panel for that top roll I'd maybe do it.
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
