07-08-2015, 08:50 AM | #326 |
Re: 72 K30 Build
Here are some pics of the lower flange holes that have gotten filled so far.
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
07-08-2015, 08:55 AM | #327 |
Re: 72 K30 Build
After grinding flush bolted on the hangers and drilled the remaining 3/8” pilots in the lower flange.
07-13-2015, 10:05 AM | #328 |
Re: 72 K30 Build
Made the final fit adjustments and drilled to 7/16” re-bolting one at a time. All the spring hangers have been drilled on the frame except for the front shackle frame brackets those were drilled over using a drill press. Really need to fix the spring bushings!
07-13-2015, 11:09 AM | #329 | |
Re: 72 K30 Build
"Yes sir, how may I help you?" Brett: "I'll take about a couple thousand 7/16 grade 8 bolts, nuts and washers please" Looking good there Brett. Keep up the good work. Looks like a roller soon Take care, Thomas |
07-14-2015, 10:41 AM | #330 | |
Re: 72 K30 Build
We’re pretty lucky in that I’ve got a nut a bolt supplier just a few miles away that will sell to me. All this shiny new hardware ran me less than $10 for mockup compared to the big box store specialty bins with the little packages and the 400-500% markup. Working the rear hangers, pretty sure this is the setup on the rear position but want to see it flipped over with springs and axle before punching all the holes.
07-14-2015, 09:31 PM | #331 |
Re: 72 K30 Build
Looking good.
Tom 71 K2500 71 K5 Jimmy |
07-15-2015, 09:37 AM | #332 |
Re: 72 K30 Build
Thanks Tom.
And we have some rear springs!
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 Last edited by 7dee2; 07-15-2015 at 09:42 AM. |
07-16-2015, 10:11 AM | #333 |
Re: 72 K30 Build
Flipped over with the rear axle in place ain’t that a looker? Ha!
07-16-2015, 01:46 PM | #334 |
Simple? What's simple?
Re: 72 K30 Build
That first photo brings back terrible memories of trying to work on the brake lines around those spring packs
Looking good, liking the stance!
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
07-17-2015, 09:46 AM | #335 |
Re: 72 K30 Build
Thanks Jim, It does look pretty dang tight in there and I'm sure the will be flying when that day comes.
Now it’s the front axles turn and it is finally a roller! Currently it sits almost level with no weight on the front end with an extra inch or so from the dollies. Last 2 pics you can see the frame rails kinda line up with the lines in that scrap paneling.
07-20-2015, 10:06 AM | #336 |
Re: 72 K30 Build
Decided to move forward with the generation correct engine cross member first instead of the K35 stuff. Pretty sure it’ll do the job and I’ve got the correct oil pan to make it work. Not 100% sure on the front sway bar mount and the trans mount we will see what fits the best.
07-20-2015, 12:54 PM | #337 | |
Re: 72 K30 Build
07-20-2015, 08:14 PM | #338 |
6>8 Plugless........
Re: 72 K30 Build
Nice work on the frame! It's really coming along nicely!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
07-20-2015, 10:59 PM | #339 |
Re: 72 K30 Build
Looking good keep up the work. I think it took me about a year to get it back on the wheels.
07-21-2015, 09:32 AM | #340 | ||
Re: 72 K30 Build
So I borrowed an early style motor mount from a friend who only had one. A block of wood was subbed for the other side this is some high tech stuff here! With the K35 trans mount just set inside the frame rails and no TC mounts we got pretty close to carb level just messing around. Left exhaust manifold is touching the cross member but I think the new poly mounts are thicker.
07-21-2015, 10:22 AM | #341 | |
Re: 72 K30 Build
Do you have SBC or BBC motor mount stands?
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) Last edited by JJorgensen52; 07-21-2015 at 10:28 AM. |
07-21-2015, 03:23 PM | #342 |
Re: 72 K30 Build
If the poly mount isn't tall enough, you could always shim the engine up if you had to to clear the cross member.
07-22-2015, 09:51 AM | #343 | ||
Re: 72 K30 Build
Both the 73 K5 and the 84 K35 stands we have are for a small block, the motor mount take 3 bolts to mount to the stands not 4 like the big block version. I'm thinking ours are the short/wide you describe and have noticed that our later K35 version does seem to be a little heavier duty with extra mounting provisions to the frame and cross member but are still pretty much the same overall dimensions. Quote:
While waiting for the new motor mounts to show up we’ll get the crossmember mounted and start to figure out how we will mount the sway bar. Really want to run the original front cross member if possible and these later sway mounts are not helping that goal as much as I’d like. So, so close but no cigar!
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 Last edited by 7dee2; 07-22-2015 at 09:57 AM. |
07-22-2015, 10:50 AM | #344 | |
Re: 72 K30 Build
http://67-72chevytrucks.com/vboard/s...d.php?t=140216 Food for thought
07-23-2015, 09:43 AM | #345 |
Re: 72 K30 Build
Great minds do think alike Jim, I saw that thread and thought wow! Here’s another one closer to what we'll end up with http://67-72chevytrucks.com/vboard/s....php?p=4935792 . Forum member snj8198 did a great job so all credit for this design goes to him. We lucked into some scrap 2x4 tubing a buddy had laying around and it was just perfect.
07-23-2015, 10:36 AM | #346 | |
Re: 72 K30 Build
Nice progress!
07-23-2015, 11:11 AM | #347 |
Re: 72 K30 Build
That is a good idea for mounting the sway bar. I just might have to do something like that.
07-23-2015, 04:46 PM | #348 |
Re: 72 K30 Build
That is a great idea. I may have to alter the tube a lot due to my front cross members being modified for inline 6's.
07-24-2015, 10:51 AM | #349 | ||
Re: 72 K30 Build
07-27-2015, 10:40 AM | #350 |
Re: 72 K30 Build
Here's another reason I wanted to stick with the original front cross member. I’ll tell you what these blazer steering box supports don’t fit the 133” or 157” frames real great. But with a little trimming it’s going to work out just fine, still need to add an upper shim to complete the fitting but you get the idea.
Tags |
72chevy, dually, flatbed, k30, motorhome |
