Collector of Projects
Re: Dash light bulbs LED?
I used them in my Blazer. You can no longer dim them with the factory switch. You would need to add a PWM (Pulse Width Modulator) to dim LEDs. Also, I took the cluster apart and painted over the mint green with a gloss white. I did this because I used red LEDs. Make sure the LEDs you pick have diodes that point sideways to illuminate the entire cluster.
