Old 07-24-2015, 08:48 PM   #1
sbc10guy
sbc10guy's Avatar
heater core non ac in ac truck?
I just noticed my heater core leaking today and i have a factory ac truck, My question is will a non ac heater core fit even though they are different. Im only asking because i have an extra non ac heater core. Im assuming it wont work or they would be the same but i had to ask. Thanks
1969 shortbed c/10
1998 GMC sierra
sbc10guy is offline   Reply With Quote
Old 07-24-2015, 09:45 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: heater core non ac in ac truck?
Don't remember right off but it's the brackets that want work right on the non AC heater core the outlets are in the way. It's been a long time since I replace mine but memory serves me right that why you can't use it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 07-24-2015, 09:57 PM   #3
Bigdav160
Bigdav160's Avatar
In non A/C trucks, the core is where the A/C evaporator is on an A/C truck.
A/C truck heater core is inside under the glove box.
Totally different designed parts
BTW, the aftermarket heater cores do not fit without some tweaking
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-25-2015, 12:13 AM   #4
HUSTLESTUFF
I just replaced mine from rock auto and fit real nice. Slight tweaking of tubes to go thru firewall holes. Cheap too. Mike
HUSTLESTUFF is offline   Reply With Quote
Old 07-25-2015, 06:05 AM   #5
hdff
hdff's Avatar
They show 2 did you use the cheap aluminum one or the copper looking one?
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 07-25-2015, 06:51 AM   #6
7tee
7tee's Avatar
I just installed the aluminum one from NAPA and it was a perfect fit...
7tee is offline   Reply With Quote
