![]() Join Date: Oct 2009
Pic Request: 10-16.5 vs 9.50-16.5 tires
Looking for photos for comparison:
10-16.5 tires (on 16.5x8.25 rims most likely) vs 9.50-16.5 tires (on 16.5x6.75 rims most likely) Thanks, trying to decide. The 9.50 tires is a tad taller (but also a tad skinnier), and the tallness is kinda important to me on a k. Really trying to decide if I will go with a retro mud tire or a radial. BFG A/T come in 16.5 now, but they are TALL. Not sure I wanna go that tall. Anyhoo, thanks gents, look forward to seeing whatcha got. |
Re: Pic Request: 10-16.5 vs 9.50-16.5 tires
Bump and a request for 12-16.5 pictures too.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Carpe manana
![]() ![]() Join Date: Dec 2010
12 x 33 BFG ATs on 16.5 x 8.25 - at the time I bought these tires BFG was no longer making the AT in a 10" width for 16.5
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Thanks Pete. Man o man, that truck...!
SWB 4x4 Collector
![]() Join Date: Jun 2001
Here's the 9.50s on a k20. I bought the same exact tires for mine after seeing these.
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
To be more specific we are looking at the bias ply tires and in reality the 10-16.6 and a 9.50-16.5 spec at about the same diameter with the 10s on 8.25" wheels. Where the 12-16.5 should give him almost another two inches on 9.75" wheels.
Back in the bias py days the aspect ratio was not standardized, only width. Tire height could vary between designs, but they were generally a similar diameter. 12.00s were 32" back then and it wasn't till BFG radials that they became 33/12.50s. The difference between 9.50s and 10.00s is bigger than it sounds. The 10.00 was an obviously larger tire, even if the section width was only 1/2" different. 16.5s came out when the trend came about for wider track "Wide Oval" tires, while the 16s remined a tradition tall narrow truck tire.
Here is a picture of a 10.00 x 16.5 mounted on an 8.25" wheel:
Carpe manana
Not what you are looking for but what the heck, here's a "take off" 72 K20 spare 16.5 wheel - 8.75" bias ply tire. Still holding air.
Thanks all, really appreciate the help. Trevor, that is the direction I was planning to go, and now it's clinched! Are those 8.25s or 6.75s?
SWB 4x4 Collector
His in the pictures was 6.75" and I plan to mount mine on the 8.25" I have. Havent mounted them due to fear of dry rot after mounting. I would have got the 12-16.5 tires in the same tread but they were hard to find. I would have put those on my 10". Trevor
Why are white steelies just SO FREAKIN' COOL on these trucks?
Because they belong
Those are 33/12.50-16.5s mounted on 9.75s. They are Kelly AWRs, but Kelly stopped offering 16.5s. The tread section is wider on those than the BFGs. BFG always used a narrow tread section, which is good for less rolling resistance. These were my flotation set for the beach, so wider tread for flotation
