Sources for "basic" heater?
Is there a place that stocks the basic heater for our trucks? Not sure where to get one but the deluxe heater I have takes up too much underhood space. Any suggestions or places that stock this would be wonderful.
Senior Enthusiast
Re: Sources for "basic" heater?
Junk yards or Ebay. That's where I found mine. I'm not aware of any supplier stocking originals.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
Do you know if I can use any 60-66 heater?
60-66 Nut
To my knowledge the recirculating heater was only used '60-'63. However, there is no reason one couldn't be installed into a '64-'66. You will use only 2 of the 3 levers on your heater control. The fan lever and the heat/defrost lever.
![]() Join Date: Nov 2008
I believe I have one .. Will get pictures tomorrow ... PM'd you ..
I got a basic heater from Ecklers. They were having a sale and I grabbed it for 9.95 plus shipping. I had a deluxe heater that was leaking and didn't want to spend the money to have it rebuilt (est. $350 @ the local shop) I had to mid if the housing as the inlet and outlets were for a basic not a deluxe. A little dremeling and she fits like a charm. Of course the heater is on all the time when I open the valve in the engine from the engine but for now I'm fine with the fix.
Posted via Mobile Device |
If you don't care about originality here are 2 from Speedway Motors.
http://www.speedwaymotors.com/Speedw...BTU,73715.html http://www.speedwaymotors.com/Flex-A...eater,304.html
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
With the economy heater in a 64-66 I can just adapt the cables to my stock controls? And just run a fan switch? In terms of shutting off hot water to the core I could always add a mechanical valve or does it have that from the factory?
![]() Join Date: Jul 2015
Just picked one up from http://www.aspenautoaz.com/ it came packaged well and was in great shape. I was able to get the dash lovers control cable switch and wires as well
http://67-72chevytrucks.com/vboard/s...d.php?t=675881 1972 C-10 SWB 1962 3/4 ton LWB 2011 GMC Sierra LML Z71 crewcab shortbed |
Thanks. I got the under hood part out today. Can I safely remove all the sheet metal ducting under the dash too if I intend on going with the economy setup?
Yes. The econo box replaces everything inside. If your soft duct lines are hard and cracked you might want to replace them as well.
Thanks! The soft lines are completely missing. Removing that heater box from outside really opened up room for the twin turbos!
#13 | |
![]() Join Date: May 2010
Twin turbo's awesome!
It only has original paint once |
It will only be awesome if I can get the plumbing to fit. Picture a bundle of snakes in a really small space. Thats about what its looking like.
