1972 rear air switch help !!!!
I had to take the plug off the wires in order to fish it down the front windshield post. Now that i am getting back to completing the wiring i cant find the diagram i made as to what wire goes where. All i need is a pitcure of the wires that plug onto the rear air switch in the dash. Thanks for any help !!
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Re: 1972 rear air switch help !!!!
Does this help?
Could you describe the layout ? I can quite make out the positions you have what i need to answer my questions there
is the yellow on the bottom ? top left is red and top right blue ?
Yes!
Thanks so much !!!!!!
So when i turn on the switch there are 3 speeds in the order of - high- low then medium does that sound right ??
OK, My switch may just appear to be wire that way.
Here's the service manual wiring schematic. It looks like the blue and yellow are switched
Hello all. I'm new to this forum, as I just purchased a '72 Suburban. It has a - what appears to be - functional rear air conditioner. I think the dash switch has seen better days. Of the 4 position switch, off works
![]() Thanks! |
Just following up on my earlier post. I was able to get a replacement switch from Randy500 in this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=725056 Thanks Randy500!
