Old 07-21-2015, 11:01 AM   #1
Jaysonb
Jaysonb's Avatar
Help with tire size
I picked up a 80 short stepper, it has 2" drop spindles with 2" drop springs in the front, and the rear axle is flipped, with about 2" lowering blocks as well. It has rally wheels on it now, but I would like to put some 18x8 mb old school wheels on it. I think it looks good when people put bigger tires in the rear, but I would like to find a good size 18" tire I can put on all 4 corners. The wheels are 18x8, with 0 offset. They also have a 20x9.5 with a 0 offset that would look good in the rear, but I'm not sure what size tires would look good. Thanks for any help.
Jaysonb is offline   Reply With Quote
Old 07-22-2015, 12:31 AM   #2
UKNOWME
UKNOWME's Avatar
Re: Help with tire size
That offset probably won't work well. I would discourage that.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 07-22-2015, 06:40 PM   #3
Jaysonb
Jaysonb's Avatar
I guess that 0 offset on a 8" wheel is 4.5" back spacing. What back spacing would you suggest for a 18x8 wheel.
Old 07-22-2015, 07:28 PM   #4
UKNOWME
UKNOWME's Avatar
I'm sorry. You are correct. I thought 0 offset would be 4 BS but it is indeed 4.5 BS. I'm running 4.5 and although they work it would be better to get around 5.25-5.5.
1964 Chevy c10
Old 07-24-2015, 08:38 PM   #5
Tilt
These are MB Old School 20x9.5 with 0 offset/5.22" back spacing with a 275/45/20 on the rear. The truck has a flip kit on the rear and 3" spindles with one coil cut off the factory springs in front. The fronts wheels are 20x8.5 with+7 offset/5" backspacing and a 245/40/20
'83 Silverado Step Side
'85 GMC short bed.
'86 Chevy Step Side Custom Deluxe
LQ9/4L80 swap (SOLD)
Tilt is offline   Reply With Quote
Old 07-27-2015, 10:37 AM   #6
Jaysonb
Jaysonb's Avatar
Wow! Thanks, that is exactly the look I'm going for. I think I'm going to have to raise this truck up a little, I have drove it around a little, and it seems that the smallest bump, or driveway approach hits the lower control arms. It should be a fun project truck.
Old 07-27-2015, 10:56 AM   #7
Jaysonb
Jaysonb's Avatar
Here is a few pics.
Old 07-27-2015, 01:48 PM   #8
UKNOWME
UKNOWME's Avatar
I'd wait until you put new wheels and tires on before lifting it back up. Depending on what size it may be enough of a lift on its own. Maybe even lower that back a couple more inches and that'll bring the front at a different angle.
1964 Chevy c10
