My window comes off track - Help
Hello,
My driver side window can slide backward and forward slightly, when it is partially open. This allows the window to slide rearward slightly and move out of the verticle felt channel, just behind the vent window. This allows the window to move inward, toward the drivers seat. You then have to roll it down some, and push it forward slightly before you can properly roll it up. I just disassembled and reassembled it, but that didn't fix the problem. Sorry the pictures are displaying sideways for some reason. What is causing this and how do I fix it? Thanks, Jason Last edited by jason999; 07-27-2015 at 03:13 PM. |
Re: My window comes off track - Help
Ok, so I just went outside and took the panel off of the passenger door. It looks like there is a track at the door latch side on my passenger side door. The track is missing on my driver side door. My weather stripping just hangs loose inside the door. In other words, the window on rides on the vent window track, inside the door.
My driver door had a bear claw latch installed by the PO, which I have removed. I am guessing the track was removed at that time. Where can I get the track that holds the weather stripping? How/where does it attach? |
#3 | |
#4 | |
#5 | |
Moderator
![]() ![]() Join Date: Aug 2011
Santa Maria
Thanks guys. That window was driving me crazy.
The rear channel was just gone! I got lucky and found one on craigslist from some nice folks about 5 miles away. I also got a few other parts. I'll try to get it installed tomorrow. I will have to do something about the big hole in my door eventually, though. Thanks |
