Old 07-26-2015, 03:46 PM   #26
F.A.A.benny
Re: AC Compressor Question
I can see in your picture that you installed a poa update kit. Whats your opinion on it?
F.A.A.benny is offline   Reply With Quote
Old 07-26-2015, 03:48 PM   #27
F.A.A.benny
Originally Posted by Bigdav160 View Post
Really Cheap
They have hose and fittings also
Old 07-26-2015, 04:03 PM   #28
hdff
hdff's Avatar
Originally Posted by F.A.A.benny View Post
This is a direct fit parallel flow condenser just haven't been able to confirm who makes it. And Old Air Products does not look like this at all
That looks nice. I have 2 stock condensers in the attic but when I do this I want to do it right and work well
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 07-26-2015, 04:23 PM   #29
F.A.A.benny
I agree, it does look good. and parallel flow along with the recalibrated poa(or rebuilt if it needs it)valve is the way to go if using 134a
Old 07-26-2015, 04:56 PM   #30
Bigdav160
Bigdav160's Avatar
Unfortunately I haven't run the engine... yet. I'm having ignition issues with my microsquirt engine controller. My choice of short block (880 Vortec) had me abandon my factory brackets (and new axial compressor) because the short water pump wouldn't fit over the plastic timing cover. So I installed a Camaro serpentine setup and a new R4 compressor.
If the cycling system doesn't work to my satisfaction I'll be putting the POA back on.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-26-2015, 06:23 PM   #31
leddzepp
Moderator
leddzepp's Avatar
I have seen some pics of it but not sure that's a pf condenser. It looks to have cylindrical tubes resembling the original tube and fin style, although smaller looking in diameter. Havent called them to confirm
Call to confirm, I'm pretty sure it is. There was a guy on here that converted to 134 recently and bought all the parts from old air.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 07-26-2015, 07:36 PM   #32
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: AC Compressor Question
My setup is from Classic air.
http://www.classicautoair.com/
Very nice people to deal with and they know there stuff.
I bought the Sanden compressor, brackets and hose kit with condenser for 134A. The tubes are bigger for more expansion so that the 134A will flow better. Thus helps with the cooling effect. I did away with the POA and drier altogether. I also closed off the outside cowl vent for better cooling inside the cab.
My AC runs from 40* to 50* depending on how hot it is out side on 100* days it will be closer to 50* but any AC tech will tell you 40* difference is awsume.
Mine will stay at the same temp sitting in traffic to.
The kit I got!
This picture shows the condenser that I installed.
I did away with the old POA valve and dryer and added the accumulator.
This last picture shows it since the 6.0 LS swap so the bracket has been changed out.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 07-27-2015, 04:28 PM   #33
F.A.A.benny
The kit I got!
The picture with your grill removed showing the condenser you installed doesn't look like the one in the picabove of the Classic Auto Air kit. That looks like the factory tube and fin condenser.
Old 07-27-2015, 05:23 PM   #34
Bigdav160
Bigdav160's Avatar
It is tube and fin. Serpentine too.
The one in the add I believe they call it "piccolo" in this picture. The universal one I purchased looks like the one one the right.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 07-27-2015, 05:33 PM   #35
F.A.A.benny
That's what I was thinking too. Good visual illustration.. That's why I was saying that I didn't believe the ones offered by old air products as a direct bolt on to be a parallel flow either. They look like that piccolo. Here is a pic of their condenser
Old 07-28-2015, 12:31 PM   #36
Andy4639
Old member
Andy4639's Avatar
Wink Re: AC Compressor Question
That's because the kit picture is a generic picture. It shows the dryer also. Which I don't have, it's a generic and they sell you the one you need, Da!
It's made for the 134A Freon.
Old 07-28-2015, 12:41 PM   #37
leddzepp
Moderator
leddzepp's Avatar
This is usually the case...which is why people should call and ask. That will remove all doubt and answer the question.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 07-28-2015, 12:47 PM   #38
F.A.A.benny
oh ok, I just thought what was in the pic is what one would get. Either way, neither one in the generic pic or the one on your truck is a true parallel flow condenser. At least not by the pic above showing the different types on condensers. But if it works then it doesn't matter.
Old 07-28-2015, 01:02 PM   #39
Andy4639
Old member
Andy4639's Avatar
I never said true parallel flow condenser for either one. I said they sold this one to me for 134a only with more and bigger tubes for expansion. I have no idea where you got the true parallel flow condenser part.
My system works great! I was just putting info out for a swap that I performed back in the early 90 and has work with no problems since.
Old 07-28-2015, 01:23 PM   #40
Bigdav160
Bigdav160's Avatar
If it's working for you nobody is complaining.
It's not the "expansion" that is important as we're talking about the "condenser". To condense back to a liquid we have to get rid of the heat. That is done with more contact area via the tiny tubes. Parallel flow lets the liquid to drop out while the hotter vapor to stay in the top of the condenser.
Simply put, R134a requires more condenser than R12 to get rid of the heat otherwise pressures are higher and the system is less efficient.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 07-28-2015, 01:36 PM   #41
F.A.A.benny
[QUOTE=Andy4639;7256425]I never said true parallel flow condenser for either one. I said they sold this one to me for 134a only with more and bigger tubes for expansion. I have no idea where you got the true parallel flow condenser part.
[/QUOTE
There was probably a misunderstanding. The discussion of parallel flow and where to buy started before you posted. That's where "the true parallel flow condenser part" came from.
Old 07-28-2015, 04:47 PM   #42
Andy4639
Old member
Andy4639's Avatar
Ok, that I understand. I was just saying mine wasn't. Just was making sure the info I put out was correctly took.
