Old 06-30-2015, 11:51 AM   #1
69_partiwgn
Best rear coil spring 69 Burb
So this weekend I dropped the back of my 69 burb using 4" CPP springs, Now the axle is at the bump stops. Which springs would be better that are firmer? I would like to haul a bit more than air, or do I now need to c notch the frame? these are too soft. I have a set of 2" fronts yet to go in, are they just as soft as the rears? Thanks guys
69_partiwgn is offline   Reply With Quote
Old 06-30-2015, 11:16 PM   #2
Average Joe
Average Joe's Avatar
Re: Best rear coil spring 69 Burb
You might consider a Burb specific rear drop spring. They are built to compensate for the extra weight of the suburban. GMC Pauls sells them. Another option would be to bag the rear. This will give you the flexability to raise and lower the rear as needed.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 06-30-2015, 11:58 PM   #3
CG
BlahBlahBlah
The burb/panel drop springs are really heavy duty when you do a side by side with the truck drop springs. I think mine came from CPP. I used to have a pic of the side by side but I cant find it anywhere.
Old 07-01-2015, 10:18 AM   #4
4shongo
I have the CPP 4" heavy duty rear springs on my Burb and have no issues. Did you order the regular springs or the heavy duty ones? I have the 3" springs up front with no issues as well.
4shongo is offline   Reply With Quote
Old 07-01-2015, 07:31 PM   #5
69_partiwgn
They were regular ones, I picked them up from LMC when I was in Kansas. I have read a lot here that 4" is usually not a problem that why I questioned if I had picked up the wrong ones
Old 07-01-2015, 07:33 PM   #6
69_partiwgn
Do you have heavy duty in the front as well?
Old 07-02-2015, 03:18 PM   #7
4shongo
HD only offered on the rear. For $120 you might should buy a set and try them out. Might be able to sell your regular ones to a truck guy. Just my $.02!
Old 07-02-2015, 04:28 PM   #8
69_partiwgn
Do you have a pic of your burb? I'm curious how low it is
Old 07-02-2015, 05:37 PM   #9
4shongo
If you search some of my other posts you can find a few pics of mine.
Old 07-10-2015, 07:26 PM   #10
geemac
I have a 72 Burb with a recent front end rebuild with 2.5 inch dropped spindles and factory front springs. Wheel arch measurement through the center of the 15 inch American Racing Torque Thrust wheels and BF Goody 225-70-15 front tire is 29.5 inches. Perfect look for me. The original back springs are nearly solid (little to no coil separation) and the wheel arch measurement is 30.5 inches, which looks good sitting still. I have a set of new factory Burb springs and would like someone to give me a wheel arch measurement if they have new factory springs in the rear (include tire size). If anyone out there have used 2-3 inch dropped rear springs, give me a wheel arch measurement and your rear tire size...pictures would be nice too! Just trying to arrive at the best guess rear ride height so I'm not too high or too low. My rear tires are 255-70-15 and the current rear wheel arch measurement is 30.5 inches. I would like my rear arch about the same, +/-.5 inches. Thanks!
geemac is offline   Reply With Quote
Old 07-13-2015, 02:37 AM   #11
fourspeedwagon
fourspeedwagon's Avatar
Geemac- I seem to remember a thread that included the info your looking for. Maybe try a search? Mine is similar to yours but no clue how high it is supposed to be. Good luck and if you find it, bump it to the top so we all can find it?
fourspeedwagon is offline   Reply With Quote
Old 07-17-2015, 12:39 AM   #12
CG
BlahBlahBlah
I found the picture of the spring comparison if any one is still interested
Old 07-26-2015, 08:47 AM   #13
69_partiwgn
Thanks, yep I need those, CPP correct??
Old 07-26-2015, 08:48 AM   #14
69_partiwgn
Thanks for finding it
Old 07-26-2015, 03:59 PM   #15
69_partiwgn
Today I put in the front 2" drop coils, that may have lifted the burb up...the pic with the c10 is before, one without is after.
Old 07-26-2015, 04:02 PM   #16
69_partiwgn
After
Old 07-26-2015, 04:04 PM   #17
69_partiwgn
Before
Old 07-29-2015, 01:04 AM   #18
Billyburban
Are these the CPP HD ? Cause I bought the HD ones for my suburban an its sitting on the rear axle
Billyburban is offline   Reply With Quote
Old 07-29-2015, 01:06 AM   #19
Billyburban
Sitting on axle
Old 07-29-2015, 12:25 PM   #20
69_partiwgn
Mine sits the same in the back with the reg springs, yours do look heavier than mine. I was surprised that I didn't get any drop in the front.
Old 07-29-2015, 12:29 PM   #21
Billyburban
I'm on the phone with cpp wright now let's see what they say
