Where to mount the ECM?
Ok guys I am getting ready to mount my ECM in the engine bay and was wondering what everyone else has done. Let's see some pics.
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
Junior Member
![]() Join Date: Sep 2013
Re: Where to mount the ECM?
This is my 72 k20 it's mounted drivers side radiator support
meowMEOWmeowMEOW
Some folks rolled their eyes at me for exposing all of my wiring in the engine bay, but its easy to troubleshoot and the ecm has effective cooling there. Its been like this for a couple yeare but I'll be forced to move it when we take the inner fenders out.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
![]() Join Date: Jul 2010
I put mine inside the glove box along with all of my fuses and relays.
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
#5 | |
Thanks for the pic. Posted via Mobile Device |
#6 | |
![]() Join Date: Oct 2012
hello to all. it looks easy, but everything was welded. good luck
![]() Join Date: Nov 2013
Great idea, thanks for posting pictures!
Did mine similar to TRKFRK. Made a bracket and mounted it behind the glove box so that the ECM would be at an angle. I trimmed the card board to hide the ECM but still be able to use it as a glove box. The only thing you can see when you open the glove box is the OBDII port
#10 | |
![]() Join Date: Sep 2014
I put mine on the passenger side inner fender, I took the factory bracket and cut off the extra plastic and then put rubber feet on it and screwed it down. It works great and should not get to hot. I tried to find a good place in the cab but I did not want to lose the glove box and this just seemed a lot easier.
are you guys using stock truck harnesses? and are you modifying them at all? or are these stock length? and do you tie them into your existing truck harnesseS?
meowMEOWmeowMEOW
Mine is a custom made harness, but IMO the most versatile stock harness to start with is the service vans. Its got the longest main branches, and everything comes out in only a few places.
The trucks, cars and vans all have the same wiring types, just in different lenghts/branches.
Collector of Projects
Here is a nice mount that can be used in many different locations... $45
http://www.ironworksspeedandkustom.c...prod/prd61.htm ![]() |
#15 |
Old member
I put mine in the glove box also. I cut the backside of it out for the connections to come through and it fit nice and tight no movement at all.
I still have a little storage room but I use the center console for most stuff anyway! ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#16 |
