Old 07-28-2015, 08:58 PM   #1
Dm1pfoy1
Dm1pfoy1's Avatar
Carb or Ignition adjustment?
So I have barry grant 750 dp carb and I have a issue im not able to figure out.
So under throttle 50% or better rpms can be as low as 1k there will be a flash/pop (much quieter than carb or engine backfire) almost like a cough on cold start.It will cut power for moment and recover without dying (typically i let off throttle).
I think im over fueling or not enough timing but its rich to point it will gas me out of garage so not leaning out and there is no ping that would lead to believe its lean either.
Does anyone have reliable info on how to 4 post tune carb and tune ignition?Really need help this is first 4 post I have had.
Running 4* static/idle timing i dont have dial light to test high end of timing
Dm1pfoy1 is offline   Reply With Quote
Old 07-28-2015, 09:15 PM   #2
pwdcougar
pwdcougar's Avatar
Re: Carb or Ignition adjustment?
What motor are you running? 750 is a lot of carb. What is your initial advance set at?
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 07-28-2015, 09:24 PM   #3
Dm1pfoy1
Dm1pfoy1's Avatar
Paul
Its very mild 383 487x heads and "rv" cam specs unknown for sure think similar to 1102 summit cam. Its more carb then whats prolly recommended but until i can get heads and cam that take advantage of it im stuck.If by initial you mean set at idle im running 4* before. Sorry can never remember my timing terms.
Old 07-28-2015, 09:34 PM   #4
Fldawg
Fldawg's Avatar
check your float level and the o rings on your needle and seat, had the same probelm with my 650 dp
"Send in the clowns the goats are loose"
Fldawg is offline   Reply With Quote
Old 07-28-2015, 09:40 PM   #5
Dm1pfoy1
Dm1pfoy1's Avatar
I also feel I should add I did spring swap on dizzy which helped hugely. Was running heaviest springs now running middle set not black super lights but next step up. I know im running low on timing but want to make sure I set things on safe side because I had a ping between 10* and 12* before on the old set springs and with these being lighter im trying to be conservative.
Old 07-28-2015, 09:43 PM   #6
Dm1pfoy1
Dm1pfoy1's Avatar
I thought sticky float might be issue hadn't checked it yet and because I was unsure I wanted to check here first but will now. Thank you
Old 07-28-2015, 09:45 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Only 4 degrees initial timing is running less timing than a stock 350. Bump that up to 12 to even 16 degrees initial and see what you get.
What jets are in that carb? front and rear.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 07-28-2015, 09:48 PM   #8
Dm1pfoy1
Dm1pfoy1's Avatar
Gary
Sorry had to edit phone messed up.
I dont remember jet #'s without looking.
So I guess my inexperience lies in where do I set carb so that I can run that much timing because I do not know these carbs well. I know carbs but these are bit different. Where should I set carb so that its not too lean causing need for low timing? Like i said was having ping at 10* so I must have set carb too lean making whole setup run lean at 10* right?
Old 07-28-2015, 11:02 PM   #9
ol'blu72
Set timing first then adjust carb. You will be running around in circles if you dont. Also what dist. are you running? Vacuum advance hooked up?
Brad
72 Blazer CST 350/350/205
ol'blu72 is offline   Reply With Quote
Old 07-28-2015, 11:05 PM   #10
Dm1pfoy1
Dm1pfoy1's Avatar
HEI it is hooked up for Vac but pull it to time
Old 07-28-2015, 11:15 PM   #11
geezer#99
geezer#99's Avatar
If you only get 10 to 12 before pinging it's possible your timing tab/balancer isn't accurate.
You'll need to check that.
Look here.
http://www.crankshaftcoalition.com/w...op_dead_center
Also your running rich is because you're idling on the power circuit.
geezer#99 is online now   Reply With Quote
Old 07-30-2015, 11:47 AM   #12
pwdcougar
pwdcougar's Avatar
Pinging at 10 is way too soon. Is it possible that the cam wasn't installed straight up?
Paul
Old 08-01-2015, 11:30 PM   #13
Dm1pfoy1
Dm1pfoy1's Avatar
Paul
So there is 4* timing advance on cam install. I am presently at 10* inital time with static timing that would be 14* I was able to start from 0 turns and at 2 1/4 turns now there is no pinging. So both were wrong. So once i found timing and got that set I counted turns backwards on each post then added 50% put me at 3 turns was running really rich and used 1/4 increments and finally got to 2 1/4.
Old 08-01-2015, 11:45 PM   #14
geezer#99
geezer#99's Avatar
Cam timing has nothing to do with dizzy timing.
You can't add them togethor.
Advancing or retarding cam timing moves the torque curve up or down the rpm scale.
What are you talking about when you say you started at 0 turns and at 2 1/4 turns there is no pinging?
Have you proved #1 tdc is accurate yet on your timing tab?
Old 08-02-2015, 12:38 PM   #15
ol'blu72
When you are talking turns are you talking about tuning the carb?
Brad
Old 08-02-2015, 07:39 PM   #16
mike16
not alot to go by but ...here goes
because th lean condition occurs under throttle I would guesse that your little plasic accelorator cam on the side of the carb pumps too much fuel in the first part of its travel and the acceloratore system reservoir runs out as it , the cam, tries to pump whats suppose to be left in the reservoir during the second part of its travel. but because the cam is too radical for the application it pumps too much fuel at the geginning and runs dry befor the main jets catch up. quite common when people set up a carb that is too radical for the engine.
if somebody is standing behind the truck while it is acceloratig and sees black smoke comming from your exhuaste as you accelorate. thats probably what it is. Aslo maybe you may be hearing a mild or soft popping noise from your tail pipe, thats an indication of an overly rich setting causing raw fuel to ignight in the muffler. This would occur at the beginning od excelloration
and then at the accellorator resivoir runs dry you then get the symtoms of a lean condition with the popping up through the carb.
Its an easy fix. I think there are 5 to 7 of thos accelorator cams available. each with two mounting holes so you have about ten possible setting, some cames actuly have three holes with settings. so you can explore tose various settings.
if you experience a rich mixture indication in the first half of ecceloration I wouls fix that and see if the lean condition goes away too. if it does not than select another cam that extends the time period that the accelorator pumps fuel up to and beyond the point where the lean condition occurs.
I dont kno alot about the four corner carbs but witha four corner idle system you dont need a 50 cc pump but again I dontknow alot about your engin parameters and specs.
if you cant solve it with pump cams then I would look at fuel starvation.
Timing is easy to diagnose, check with a timing light and check for vacuum leaks and be sure your advance is working. not rusted if not get a quality adjustable advance, or for a points system get one from a year compatable with your engine. My '72 c 10 307 used a 74 corvette advance when it was points, when I converted to an HEI i went to a 75 corvette HEI advance. NOS cost more but quality is consistant. Replacements adjustables are easier to find and can be adjusted. Some advance kits come with springs and bushings in the kit. Still years later the quality of the return spings are iffy. I would recomend springs from MSD
A lean condition will continue to exist, symptoms and all, no matter what your timing is set at
I hpe I have not confused you nd I have not made any mistakes here. I dont know the 4 corner sytstem. but its a Holley by another name.
I think there Is abook By SA on the 4 corner pumps written by David Vizard.Well written by an incredable and gifted engineer.
so you may be getting rich mixture signals at the beginning of acceloration but when the
mike16 is offline   Reply With Quote
