Old 07-31-2015, 08:17 AM   #1
LockDoc
The Older Generation
LockDoc's Avatar
Re: Wing window questions
Originally Posted by Sklptrljay View Post
Hey, digging up this old thread. I have the same issue with my drivers side wing window. It will stay in the closed position fine but if I try to open it the pivot point will pop loose. So looking at the attached LMC diagram it looks like I can tack it back together. Is it that simple or am I missing something?
Is the spring just a tensioner to keep the window from flopping around?
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=24
You should be able to tack weld it. That's the nice thing about the Mig welders, you can keep the welded area pretty cool. The spring is an adjustable tensioner that never gets lubed so that puts a lot of stress on the joint between the window and tensioner stud.
Check this thread out, "highwinger" and I posted a lot of info in it on removing, rebuilding, and installing vent windows....
http://67-72chevytrucks.com/vboard/s...d.php?t=660294
LockDoc
Leon
Old 07-31-2015, 09:43 AM   #2
Sklptrljay
Sklptrljay's Avatar
LockDoc
I actually read that thread last night while poking around for an answer to this. I'm lucky in having a cousin who is a 30 year auto body guy, so I can bribe him to help with the disassembly and reinstall.
Glad it's a simple fix. Thanks for the info.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
