Old 07-12-2015, 11:41 AM   #1
Jake1971
Jake1971's Avatar
WTS OEM 12 bolt differential cover
I have this OEM cover that has surface rust on the outside and clean inside I removed recently from a 1968 c-10 truck, the outer tip was slightly bent somehow but it does not affect the seal or functionality. See photos. $20 plus the ride. I can throw in the 12 bolts with it. LMK.
1971 Bone Stock C10 project "Jake"
1997 Sierra SLT factory short bed "Silver Bullet"
Jake1971 is offline   Reply With Quote
Old 07-15-2015, 06:59 PM   #2
Jake1971
Jake1971's Avatar
Re: WTS OEM 12 bolt differential cover
Ttt
Old 07-18-2015, 12:40 PM   #3
Jake1971
Jake1971's Avatar
Bump. Offers?
Old 07-20-2015, 06:32 PM   #4
Jake1971
Jake1971's Avatar
Ttt
Old 07-31-2015, 06:54 PM   #5
Jake1971
Jake1971's Avatar
bump
Old 08-01-2015, 12:47 AM   #6
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
If the edge is just bent, not cut, or the very edge damaged, then a small crescent wrench should do the trick. At least it did last night.
The bend is from a floor jack.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-01-2015, 03:02 PM   #7
Jake1971
Jake1971's Avatar
That's what it appears to be.
1967-1972 blazer, hat, original, plate, rear end
