Which clutch should I buy?
I'm going to put a new motor in my truck this weekend and was wondering which clutch to buy. The shop says they have two differant ones for my 72 K10. The first is a 12in. that has the three fingers like my original clutch for 160.00. He said they also have a newer style with a lot more fingers that is supposed to make using the clutch easier and last longer for 130.00. What do you guys think is the better clutch?
thanks, James
--------- 72 SWB K10 San Diego CA |
i have the one with a lot of fingers and i am going to go back to the one with 3 fingers i dont like the let off point of the other one it is to high and it does not have that strong feeling to it
71 Chevy C/10 lwb 350 5 speed nv3500 3.73 rear end 2.5" Front Drop and 4" in the back Edelbrock perfomer rpm manifold Edelbrock 600 cfm carb Headmen headers |
ttt
The clutches with the three fingers is called a Borg and Beck clutch. The ones with the many fingers is called a diaghram clutch. The B and B clutches will give you more pressure, unless you go with a Centerforce performance clutch which has counterweights to give more pressure with centrifical force. The more RPM's, the more pressure. I am thinking about going with a new setup from Napa that has a clutch disk with ceramic buttons on it for better grip and less wear. I was told that all of the wrecker drivers use those so they don't go through a clutch every month. It is a Borg and Beck clutch, also.
1969 3/4 ton 4x4 33's with no lift, gotta love it! A man and his truck, it's a beautiful thing. |
thanks mightyfine, I went with the diaphram clutch. I hope it works ok for me. The guys at the clutch shop said I would be much happier.
I'll find out.....
