Power steering remote reservoir hose
What do I use for the remote reservoir hose on my big block? Whatever the PO put on there sweats PS fluid right through the walls and makes a mess.
![]() Join Date: Mar 2003
Re: Power steering remote reservoir hose
Weather head Hydraulic hose, not as flexible as the OE hose but will last forever in that situation
Some of the Chevelle parts suppliers have the correct hose. Search for a big block Chevelle....that's where I got mine.....
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
You need hydraulic return (suction) line. Try a good parts store or hydraulic shop that makes hoses. Also Northern Tool or similar places sell it too.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
Here is my original post when I was looking for a replacement....part number for an oem style hose is at the end....might be cheaper to go with the hoses the other members are suggesting....
http://67-72chevytrucks.com/vboard/s...d.php?t=148527
Member #1049
Here are some part number for the correct hose
Big block PS hose (between resovoir and pump body). The #34999 CarQuest. Gates has it available in a 10' section or a 3' section. P/N: for 10' is #34990 P/N: for 3' is #362100 Rock Auto has the 3' section #362100 in stock Napa number #NPS 73306 |
OH Man! That's great info. Thanks all!
Follow-up: Just bought 3/4" fuel line (!) from NAPA, which Mr. Parts Guy thought would work for PS fluid. Only $5/foot so worth a shot.
Moderator
![]() Join Date: May 2007
A marine shop will have what you need as well.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
![]() Join Date: Dec 2009
you may be tempted to use heater hose as return lines. dont. they get soggy and sweat steering fluid. potential fire hazard too. dont do it except maybe in a pinch as an emergency.
Ya, that's why I posted. It's making a mess and it's dangerous! Thanks! Haven't tried my new fuel line yet.
| Bookmarks |
