Old 08-01-2015, 07:09 PM   #1
KevinD85
KevinD85's Avatar
upgraded head light options
I've searched on here and I've been looking for some options on getting brighter head lights for my 86 k10 silverado with the quad 150 mm headlights.
I was wondering what other people have tried and what to stay away from.
this is my truck thanks for the help
1986 chevy k10 silverado rust free from oregon 350 crate big cam,headers and 2.5" duals with an x pipe.
2001 subaru 2.5 rs with a full wrx sti swap track car project
1991 Lexus Ls400 rwd drift toy
2012 lexus is350 awd daily driver
KevinD85 is offline   Reply With Quote
Old 08-01-2015, 09:09 PM   #2
rich weyand
rich weyand's Avatar
Re: upgraded head light options
First thing is to put a headlight relay setup on it and get rid of all the wiring and connectors to and from the cab. You can get a setup here. About 20% of the way down the page: Automotive Headlight Brightener. $24.99. I have had people tell me it won't last, cheap relays, blah, blah, blah, but I got mine from here and it has been on there 3-1/2 years with no problems at all. You will have to get the correct one for your setup. Mine is the 1978 round headlights, so I got a different one. Kit came with everything, and was a five-minute install with no changes to stock wiring.
http://www.autolumination.com/headlights.htm
The other thing is to swap out sealed beams for the ones with the bulbs that plug in the back, and go to high-intensity bulbs. I got some Hella 7" rounds for mine and put Phillips Extreme Power bulbs in them. Love it.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 08-01-2015, 10:52 PM   #3
andrewmp6
Buy a good brand headlight housing like hella and skip the euro cut and diamond cut style lights.And get the headlight harness with the relays that will give you useable low beams and bright high beams.Next step up is to use a led replacement bulb kit for the h4 lights or spend a lot and get full led head lights.
Old 08-02-2015, 02:23 AM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
Had these in my truck with dual square lights.
Amazon.com: Hella 165mm Rectangular E-Code... Amazon.com: Hella 165mm Rectangular E-Code...
Old 08-02-2015, 03:03 AM   #5
rich weyand
Originally Posted by KQQL IT View Post
I love the Hella E-codes. DOTs have a low-beam cutoff in the upper left of the field for oncoming cars, but on the curvy roads around here you are blinding oncoming drivers going around RH turns. The E-codes cut off straight across.
Rich Weyand
1978 K10 RCSB DD.
Old 08-02-2015, 09:18 AM   #6
KevinD85
KevinD85's Avatar
ok I'll look into those. thanks!
Old 08-03-2015, 02:12 AM   #7
andrewmp6
For the wiring harness you can go lmc truck or a guy on here makes them i can't think of his name off the top of my head.
Old 08-04-2015, 06:43 AM   #8
piecesparts
Parts and more parts
piecesparts's Avatar
I purchased my quad headlight buckets from Vision-X, to get the quality that they carry. I then upgraded my headlight bulbs to their higher wattage bulbs. I purchased a wiring harness to connect the lights directly to the battery for the best voltage. I had to do a little test and trial to get the bulbs to work like they are supposed to. Had to move some pins around int he light bulb plugs.
I can now see a long ways down the road and with the harness, there is ano heavy load on my truck's older wiring system.
http://www.visionxusa.com/catalogs/2...omotive-guide/
Frank
Old 08-04-2015, 07:33 AM   #9
chevy-fun
chevy-fun's Avatar
Gmachinz makes the relay kit
chevy-fun is offline   Reply With Quote
