Old 08-04-2015, 11:45 PM   #701
RockTonka
RockTonka's Avatar
Re: 1958 Apache 38 Dually Dump Project
Originally Posted by Kim57 View Post
Everything is looking real good.
Kim
Thank you Kim
Originally Posted by scotts62 View Post
Sweet!
Just making more work for you to straighten out!!
Originally Posted by Advanced Design View Post
Nice work guys. Looking really good!
Thanks AD!
Originally Posted by ChuckDriver View Post
Very cool!
Appreciate that CD!
Originally Posted by Dieselwrencher View Post
Great work! I like the body door line change too.
Thanks DW, we just needed a break from sanding through the years of paint on the doors.
On that note, we started on the hood...this time using both paint strippers and sanding. It might have been easier to have these media blasted somewhere, but right now we have more time than money...so it's time we're spending!
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 08-04-2015, 11:49 PM   #702
RockTonka
RockTonka's Avatar
Also pulled the light buckets to start fitting in the halo HIDs...heavy undercoating way back when kept these parts in pristine condition.
My build thread
Old 08-05-2015, 08:02 AM   #703
lower50's
lower50's's Avatar
Great job!! How did you strip the undercoating off the headlight buckets?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 08-05-2015, 02:09 PM   #704
Kim57
Kim57's Avatar
Buckets look real good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 08-05-2015, 06:14 PM   #705
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work! Pre sandblasting those buckets, they kind of looked questionable huh? They look perfect after though.
Ryan
1969 Chevy milk truck
Old 08-05-2015, 07:57 PM   #706
RockTonka
RockTonka's Avatar
MY son was able to simply chip the hardened undercoating off before media blasting.
Kim
Yep, one less thing to worry about.
Yea, we were kinda wondering what might be underneath...those coatings can be a blessing or a curse, either protecting base metal or holding crap against it.
My build thread
Old 08-20-2015, 04:31 AM   #707
RockTonka
RockTonka's Avatar
Pulled the cab for the last time hopefully...still have alot of work left on it though. Took advantage of the opportunity to pull the chassis out and wash a bit of the dust off before moving the batteries down to the frame...also bolted a few things on to check fit before sending the steps out for powdercoating.
My build thread
Old 08-20-2015, 08:08 AM   #708
Grizz1963
Grizz1963's Avatar
Just busy making up the bracket to move my 66's battery from the engine bay to under the cab.
Yours looks 100 times more slick though.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 08-20-2015, 09:21 AM   #709
Kim57
Kim57's Avatar
Frame sure looks great.
Kim
My build thread
Old 08-20-2015, 03:20 PM   #710
lower50's
lower50's's Avatar
It always looks funny when ppl mount optima batteries on there side. Great job.
1951 MG TD
Old 08-20-2015, 03:40 PM   #711
ptc
ptc's Avatar
Can they be mounted upside down?
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 08-20-2015, 04:41 PM   #712
Dieselwrencher
It is looking great! Keep up the great work!
Ryan
Old 08-20-2015, 06:11 PM   #713
lower50's
lower50's's Avatar
You can mount in any position
1951 MG TD
Old 08-20-2015, 07:24 PM   #714
RockTonka
RockTonka's Avatar
Thanks Grizz, I took the easy way out and picked up a dual battery box from Ruffstuff Industries. All I had to do was weld a couple tabs off the bottom to mount it where we did.
My build thread
Old 08-20-2015, 07:30 PM   #715
RockTonka
RockTonka's Avatar
Kim
Thanks Kim, it was getting hard to tell with all the dust collecting on it!
Thanks L50, the all-position capability of these types of batteries opens up lots of options.
We're trying DW, thanks for checking in.
My build thread
Old 08-20-2015, 09:54 PM   #716
RockTonka
RockTonka's Avatar
Based primarily on discussions here regarding the integrity of cheap aftermarket columns, we decided to replace our cheap aftermarket column with a known name brand.
After reviewing available options, we elected to go with a Flaming River column. The difference in quality is evident in both the fit and finish and "feel".
My build thread
Old 08-22-2015, 01:54 AM   #717
RockTonka
RockTonka's Avatar
We picked up the steps from our powder coater this morning...less than a 24 hr turn-around! We really like working with them...Tops Powdercoating in OKC flat out delivers!
My son thought that the mud flaps were boring and had an idea to make them pop. We spent the evening working some 3" x 1/8" aluminum strap into these pieces...we really like how they flow with the rest of the truck.
My build thread
Old 08-22-2015, 01:58 AM   #718
Grizz1963
Grizz1963's Avatar
Very VERY Smart.
This really is an amazing build you are doing.
As mentioned elsewhere before, we may end up driving close by you in October, I still need to get my side mouldings an S/S bed strips from Mar-K but they are holding out on the extra 10% discount, which to us travelling means a lot in the greater scheme of things.
Who knows...?
Old 08-22-2015, 02:18 AM   #719
RockTonka
RockTonka's Avatar
Thanks Griz, if y'all make it through OKC and would like...we have plenty of room for y'all to spend the night and maybe let us feed ya a time or two!
My build thread
Old 08-22-2015, 07:59 AM   #720
Advanced Design
Advanced Design's Avatar
Nice detail on the mud flaps. Carrying the theme on in a tasteful way.
Good idea on getting a quality steering column.
Your truck is so awesome.
Advanced Design is offline   Reply With Quote
Old 08-22-2015, 10:01 AM   #721
Truck Guy99
Just saw your in Oklahoma City! I'm in the process of moving to elk city right now would def love to see this truck out some day
My names Tye. No Chevy right now
Truck Guy99 is offline   Reply With Quote
Old 08-22-2015, 10:47 AM   #722
Kim57
Kim57's Avatar
Great details.
Kim
My build thread
Old 08-24-2015, 07:17 AM   #723
lower50's
lower50's's Avatar
All the details really work well together!! love it
1951 MG TD
Old 08-25-2015, 01:26 PM   #724
mjh1965
mjh1965's Avatar
Rian (Grizz ) pointed me to this build thread . I am glad he did , very nice truck , and top quality work I will keep watching.
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline   Reply With Quote
Old 08-25-2015, 09:27 PM   #725
Dieselwrencher
The mud flap trim matches and looks killer! The steps look awesome too!
Ryan
