Old 08-04-2015, 10:26 AM   #1
strangestash72
strangestash72's Avatar
72 Windshield HELP
Does anyone have any advise or tricks on installing the new windshield on my 72 c10 ? It has the chrome trim.
strangestash72 is offline   Reply With Quote
Old 08-04-2015, 11:24 AM   #2
cooperhw
cooperhw's Avatar
Re: 72 Windshield HELP
Do what I did. call the glass guy. He came out a couple weeks ago and installed my front and rear glass in my 68 for $200. I was at work and when I got home it was done.
You could look on Youtube. there are many videos on the subject if you want to try it yourself. I did it twice before. 50% success.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 08-04-2015, 12:03 PM   #3
NorCalC20LWB
This is on my to do list eventually also. So, I personally have not done it, but in researching it seems to vary from "take your time, patience, and it's pretty straightforward" to "this %*#@ sucks, how does this go in!?". Here are a couple of links that may help, hope to hear how it went!
NorCalC20LWB is offline   Reply With Quote
Old 08-04-2015, 12:08 PM   #4
NorCalC20LWB
Could not post the link, try again....
https://www.youtube.com/watch?v=SOU_0HpS7To
Old 08-04-2015, 03:41 PM   #5
cdowns
cdowns's Avatar
The big tip i have is dont break the glass
Old 08-04-2015, 06:14 PM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 72 Windshield HELP
I put mine in with help from my daughter and son.
Put rope inside gasket from bottom to top with both ends of the rope in the top center to pull the gasket in and have some one putting pressure on it while you pull the rope ends a little each way and keep them even.
Get it started good and it will go right in. Having some plastic knives will help and a set of picks. Once it's in you can work the top corners into position. Use plenty of soap and water in a spray bottle also. Spray it down good before you start.
Also wash the gasket good before doing anything and let dry in the sun.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-06-2015, 10:02 AM   #7
strangestash72
Thanks for the help and The links, Im going to attempt it this weekend.
