Old 08-05-2015, 01:16 PM   #1
wrager
wrager's Avatar
Help...a little confused
I bought my '71 Sub thinking it was a K10-1/2 ton model. The SPID shows the model as KE10906 and the Vin starts with KE. Does this mean it is actually a K20-3/4 ton version? And only 256 were produced with barn doors?
What else could I look at to verify that it is a K20?
wrager is offline   Reply With Quote
Old 08-05-2015, 02:50 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Help...a little confused
The model number 10906 defines it as a 1/2 ton Suburban.
A 3/4 ton would be a 20906 model number.
The K in the VIN indicates 4wd (regardless of series); the E indicates V8 engine.
http://67-72chevytrucks.com/vboard/s...d.php?t=570059
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 08-05-2015, 04:58 PM   #3
wrager
wrager's Avatar
Thanks Keith, weird, this site:
http://outintheshop.com/prodnum.html
lists the 1/2 ton as KS and the 3/4 ton as KE. They must be wrong or I'm not getting there data.
Old 08-06-2015, 09:51 AM   #4
Keith Seymore
Yes - you are confusing the VIN coding and the model code.
They are two separate entities and the structure and meaning are different. Just an unfortunate coincidence that they are so similar in this instance.
K
1979-1986
1986 - 2019
Old 08-06-2015, 10:51 AM   #5
67 Burb
67 Burb's Avatar
Here's the model info from my 1967 service manual. The '71 info will be similar.
Bob
1967 2wd Burb, 350/TH350, 3.73 posi
67 Burb is offline   Reply With Quote
