Old 07-27-2015, 01:25 PM   #1
webfoot
Need help figuring out what brackets to use SBC LWP
I have a 70 K20 with a SBC LWP setup. It uses the typical LWP passenger side alternator mount.
I am going to add an aftermarket sanden style compressor and want to put it on the passenger side to keep the hose length down. So far, all of the alan grove & other aftermarket brackets I've seen use the same bolt on the water pump as the AC compressor brackets I'd need.
I guess I'd like to see some pics of what anybody with the LWP swap has used if you added aftermarket AC systems.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 07-27-2015, 01:40 PM   #2
MARKDTN
Re: Need help figuring out what brackets to use SBC LWP
How about switching to '96-99 Vortec Serpentine brackets? That would put the alternator left and a/c compressor more toward the right and allow for that style compressor?
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 07-27-2015, 01:52 PM   #3
webfoot
I guess that is not at all out of the question, depending on cost.. any idea on the $$ outlay requirement? I need new belts and pullies as it stands now anyway, and the alan grove brackets are $100 or so each. Plus I think my PS bracket is a SWP that has been shimmed so it is not ideal.
Guessing I would also have to get a later PS pump as the bracket would not accept an older Saginaw pump?
-me
Old 08-06-2015, 11:14 AM   #4
Big Kev-O
Big Kev-O's Avatar
A bit of a late response but when I purchased my truck it had a 350 with LWP, PS, and a passenger side sanden compressor. The bracket kit was Alan Grove and I happen to have the p/n instructions/paperwork. I removed the brakets and boxed them up when I got a vortec w/serpentine setup so no pictures available but I could post some picture of the paperwork if it helps.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 08-06-2015, 11:58 AM   #5
Dan Wales
I got a SWEET serpentine system from tll74 on here. Very nice fellow to deal with. He even goes through a component you want and makes sure it is working he also blast the parts and it arrives looking like a what GM dealer would hand you across the counter.
Very nice fellow to deal with and he knows what you need.
Dan
Dan Wales is offline   Reply With Quote
