Old 08-06-2015, 12:15 PM   #1
MercRising
LS Swap...5.3 ECU to control 5.3/4l80 or, 6.0 ECU to control 5.3/ 4l80e...Thoughts?
I'm swapping a 5.3l/4l80e into a '72 C10. Currently I have the 2005 VIN "Z" L59 5.3l/Harness/Computer etc, which is built to control the 4l60e.
I plan to run a 4l80e here b/c boost will come into play.
My question is, can you all chime in on which makes more sense?
1) Convert the 5.3l harness to control the 4l80e and also make the tune changes on the 5.3l ECU to run the 4l80e or.......
2) Get a 6.0 harness/ECU to run the 4l60e and then tune the 6.0 ECU to run the 5.3l motor?
In way over my head...it's pretty fun!
John
[IMG][/IMG]
MercRising is offline   Reply With Quote
Old 08-06-2015, 02:42 PM   #2
hugger6933
Re: LS Swap...5.3 ECU to control 5.3/4l80 or, 6.0 ECU to control 5.3/ 4l80e...Thought
Just mod the 5.3 Harness to run the 4l80E then have the ECU reflashed.
hugger6933 is offline   Reply With Quote
Old 08-06-2015, 03:32 PM   #3
Hartje
Hartje's Avatar
or pick up a stand alone trans harness. tci makes a good one- then you can mange your shift points and such.
Hartje is offline   Reply With Quote
Old 08-06-2015, 05:07 PM   #4
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
This doesnt make any sense. Then you have to get the stand alone controller too.
Get a 0411 computer if you're 99-02 and an Express Van pcm or 4.3 truck pcm if you are 03-07. Get the harness for the motor and swap a few pins for the 80 and get it flashed. Define your trans settings. Piece of cake.
If you have more questions shoot me a pm. I've done almost a dozen ls swaps.
///Ryan
1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors
1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10
1967 Chevy LWB- 454 and patina
1971 Blazer - Rusty
1968 Crewcab project
Bagd72Chevy is offline   Reply With Quote
Old 08-06-2015, 09:04 PM   #5
Dustytrix
I agree with bagd72 . It will work out best in the long run. Its only swapping a couple of wires to make the 80 work.
Dustytrix is offline   Reply With Quote
Old 08-07-2015, 08:39 AM   #6
Heavymetl
If you're going to boost it eventually, I'd recommend looking aftermarket.
I'm running Holley EFI, and the closed loop function saved my engine just last week. Boost reference line blew off the fitting and fuel pressure dropped. The Holley compensated and I never missed a beat. If I'd have "saved" money using a Factory PCM, I'd be replacing the engine right now.
I know it's not cheap, but it's worth every cent IMO. The factory PCM is fine but it's cumbersome to tune and overly complex with all the factory tables.
1970 C10
Turbo LM7 5.3/LS6 cam
PT7675/4L80E/Holley Dominator EFI/E85
Moser 9" 3.25/4 wheel discs
11.16@121.07
Heavymetl is offline   Reply With Quote
Old 08-07-2015, 11:22 AM   #7
MercRising
I'll be staying stock harness for now, If I really decide to get fancy with the set up, it will probably a few iterations from now on this project.
It's a "work truck" and I just want to bang on it and learn from it. My real dream is a bagged out 67-72 Burban with a twin snail setup.....for the family and all!!! When I get there.....I'l start puking cash on it!
Thanks for the input so far.
Any board members doing great harness conversions/ECU Flashing?
