Door won't lock from outside
I have a recurring problem with my driver door lock where it will not lock from the outside. I have paid a locksmith to come fix it three times and a month or two later the problem comes back. Anyone have an idea of what is causing this?
#2 | |
The Older Generation
Re: Door won't lock from outside
Have you lubed the door latch and lock mechanism? Roll the window down and spray some good penetrating oil (not WD-40) on the back of the lock and on the latch. You can see the latch and back of the lock inside the door with the window down if you use a good light. LockDoc
![]() Join Date: Feb 2014
Do you live on a rock/gravel road?
Posted via Mobile Device |
No, in town
#5 | |
Frustrating - I keep having to lock it from inside and climb through the passenger side to lock up my truck. |
I had a similar issue and I did what LockDoc is suggesting. I used aero kroil. That stuff works great
#7 | |
Do you have more than one key? If so does it do the same thing with all of the keys? LockDoc
#8 | |
It was worth asking on here in case someone else had the same trouble and discovered the cause. Thanks for the help! |
the next time it wont lock, open the door and try locking it with the door open. its a common problem on this site. the door has too much pressure on the lock mechanism...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten. |
| Bookmarks |
