#17 | |
Re: Parting out - 1957 3600 3/4 ton truck
The next biggest error is Cab identification. Most think that a De Luxe Cab was the better cab with a big window and a chromed heater panel in the dash. Again not so. De Luxe was the base model cab that could be optioned with a big window and a deluxe heater. A Custom cab was the high end cab that would have been optioned with a chrome trim package and better interior with or without a big window or heater. The spare cab I have available is a 1955 CUSTOM CAB and has holes for all the trim!!! it is totally bare $450.00- it had the stainless steel trim all around it. It is a small back window. it has minimal rust in the typical areas. It has been blasted and thats why it has surface rust on the outside. A spray of Rust Remover and this will be clean steel again..... Needs rear corners replaced, lower door jambs. couple small floor patches. Can do all repairs if wanted, I can do a big back window conversion too if needed @ cost+ welding time.
My Build: 57 Chevy Pro-Street Last edited by ptc; 10-20-2015 at 02:56 PM. |
