Old 07-26-2015, 07:26 PM   #1
BSimmons
69 GMC rear brake drum
After owning her for 28 years I decided new brakes were in order. Having trouble locating the rear drums for my half ton 2wd. Drums are 2 x 11 all the way around. Have the fronts that are 3" deep. Rears are 3.5" deep. Local parts houses not having any luck. Any suggestions?
BSimmons is offline   Reply With Quote
Old 07-26-2015, 07:38 PM   #2
BSimmons
Re: 69 GMC rear brake drum
By the way, what is the spring for on the front drums?
Old 07-26-2015, 09:31 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Have you tried Rock auto?
http://www.rockauto.com/
NAPA also lists them. Part Number: ND 4401071
LockDoc
Leon
Old 07-26-2015, 09:51 PM   #4
BSimmons
Thanks for the reply.
Ya... They both show the 3" deep drums that fit on the front.
Old 07-26-2015, 09:54 PM   #5
BSimmons
They have a deeper "bell" than the fronts where the lug bolts come through.
Old 07-26-2015, 09:58 PM   #6
BSimmons
A comparison......
Old 07-26-2015, 10:01 PM   #7
LockDoc
LockDoc's Avatar
What did you mean when you said in your first post that the drums are 2 x 11? That is what both of them list....
LockDoc
Leon
Old 07-26-2015, 10:03 PM   #8
BSimmons
2"wide pads and 11" inside diameter drum.
Old 07-26-2015, 10:05 PM   #9
BSimmons
Same pads on both drums.
Old 07-26-2015, 10:32 PM   #10
LockDoc
LockDoc's Avatar
OK, gotcha...
Do you know what rear end it has in it? I presume it is a leaf spring...
LockDoc
Leon
Old 07-26-2015, 10:37 PM   #11
BSimmons
Yes sir...with overloads. Spid says 3.73.
Old 07-26-2015, 11:10 PM   #12
Swm424
I believe what appears to be a spring is actually a heat dissipating coil to help in the cooling of the drums.....
Swm424 is offline   Reply With Quote
Old 07-26-2015, 11:44 PM   #13
LockDoc
LockDoc's Avatar
Looks like a Dana rear. I would think drums would be available for that.... Did you check to see if they can be turned?
LockDoc
Leon
Old 07-26-2015, 11:54 PM   #14
BSimmons
The springs are leaf with over loads. Not part of the drum.
LockDoc - we might be able to turn them but I am skeptical. Original equipment with over 175k. They are UGLY!!
Old 07-27-2015, 12:11 AM   #15
GRX
GRX's Avatar
Take the drums to a local shop. They should have a measuring tool. The ones on my '69 were also original but already beyond maximum spec.
The wrap around spring is for vibration dampening purposes. If not too rusty they can be transferred to the new ones. Not really needed so are not included anymore. Ever been in a shop and see drums & rotors being turned on the lathe? A rubber strap must be wrapped around them otherwise they will vibrate and "sing". Results in a rough grooved finish.
GRX is offline   Reply With Quote
Old 07-27-2015, 12:23 AM   #16
BSimmons
Sorry swm424... Too many springs. I missed your point.
GRX what was your solution? I am certain that we will not salvage these drums either.
Old 07-27-2015, 02:17 AM   #17
GRX
GRX's Avatar
I got new drums which are not like what you have. Yours are for the Dana 44 rear. Think LMC Truck sells them though not cheap.
Old 08-01-2015, 10:29 AM   #18
BSimmons
Still have not found the right replacement drums for this truck. What are my alternatives?
Old 08-09-2015, 07:32 PM   #19
BSimmons
I found a solution to my problem. I stumbled onto a thread started by a member with a similar issue. It made reference to a Raybestos 2067 drum. In checking the specs specs seemed to fit with the exception of the size of the lug bolt holes which are smaller than required. With the help of a 9/16 drill bit all is well and working great.
Old 08-09-2015, 07:35 PM   #20
BSimmons
Back side.
