Old 08-09-2015, 11:42 PM   #18
airdale94
airdale94's Avatar
Re: HEI Mech advance spring help/timing adv advice
Some of those vac adv are adjustable, aftermarket. You pull the hose off and stick a alen wrench in the port. I had a Pontiac with the same symptoms. Also a intake leak will do that. If your running a alum intake you should use fiber gaskets instead of blue PermaTex's.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
