Old 08-10-2015, 08:21 PM   #1
cstm68
cstm68's Avatar
Anybody running a hydraulic clutch?
I picked up a 6.0L for my 68 and would like to keep my 4 speed, has anyone converted to a hydraulic clutch? I don't think I will be able to keep my factory linkage with the 6.0. Is there a kit out there or any recommendations on how to convert it?
cstm68 is offline   Reply With Quote
Old 08-10-2015, 08:42 PM   #2
CARR33
Re: Anybody running a hydraulic clutch?
i just posted the same basic question in another section, no replies yet. hotrod hydraulics.com has a complete kit but it's pricey, and their website left me with some questions. one kit is complete and is 579+70.00 for our trucks. their next kit has everything but the throw out bearing and shims and is 379 with no extra charge. i cant figure where the $70.00 comes in. i am going to call them tomorrow. i will let you know what i find out
CARR33 is offline   Reply With Quote
Old 08-10-2015, 08:59 PM   #3
cstm68
cstm68's Avatar
I was thinking about running somthing like in this picture. Keeping the factory throw out and fork. Just need to figure out how to do the clutch master cylinder with te factory clutch petal
Old 08-10-2015, 09:11 PM   #4
CARR33
thats exactly what i am looking for, any idea where i can get a set up like that
Old 08-10-2015, 09:32 PM   #5
Taibo
$209.00 available from
http://www.novak-adapt.com
Pedal assembly is a Wilwood 340-1470
Taibo is offline   Reply With Quote
Old 08-11-2015, 03:59 PM   #6
SierraMtns
SierraMtns's Avatar
Cool Wilwood pedal. I wounder how it would mount in the truck.
SierraMtns is offline   Reply With Quote
Old 08-11-2015, 04:50 PM   #7
cooperhw
cooperhw's Avatar
I used a hydraulic system off a 2002 GTO when I put a 6 speed behind my LS motor in my 67 Chevelle.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 08-11-2015, 05:39 PM   #8
whitels1
whitels1's Avatar
I'm using an SM465 from a 74, with the original bell housing, stock clutch, Sachs NFW1050 flywheel, LS7 pilot bearing with a Howe Hydraulic throw out bearing, Tilton 7/8 master cylinder attached to the original pedal assy, been working good for years.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 08-13-2015, 02:23 PM   #9
Taibo
Remove the master cylinder from the pedal assy, drill a 1.25 in hole for the master and four bolt 3/8 in holes for the mounting bolts. Bolt the pedal to the firewall from the inside, replace the master cylinder, plumb it and you're done.
Old 08-13-2015, 11:17 PM   #10
SierraMtns
SierraMtns's Avatar
I know how a clutch mounts to a firewall. I was wondering how it would mount in our trucks and how it would look. It would look really stupid if the Wilwood pedal was low close to the firewall and all the other pedals where in stock location. Also if you don't re-enforce the firewall you will have problems. Do you have any pictures of this set-up in our trucks?
Old 08-14-2015, 01:09 PM   #11
Taibo
No, I have no pictures of that pedal in a C10. I am an SCCA racer and I usually have to make make all of the bracketry I need to install stuff like this. There aren't any parts stores that cater to that small a market so you either make what you need or you stay off the track. The Wilwood pedal is not meant to be supported by the firewall alone. You are expected to fashion a bracket that supports the TOP of the pedal assembly. That bracket includes a support and attachment for the clutch return spring and the clutch "disengaged' sensor for the engine computer if you are running one. A typical bracket for the front mount pedal I posted is shown in the drawing below. Pedal length and pedal angle are adjusted by cutting and either adding or taking out a section of the pedal arm and re-welding to get the correct fit. It's a cut and fit process but usually works well if you are patient, use cardboard templates for the pedal arm and the mounting bracket.
Or, as a alternative, pull the brake and clutch pedal quadrant out of a wrecked truck compatible with yours and mount the clutch master to that.
Old 08-19-2015, 04:05 PM   #12
67chevemall
67chevemall's Avatar
Subscribed.
Would be a sweet upgrade. Now a button on the shifter handle would be cool.
My clutch is a work out to say the least.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 08-19-2015, 04:22 PM   #13
Aruba1
I am running a 1997 NV4500 with internal slave cylinder and a OEM clutch MC. I choose to use the used slave cylinder and it started leaking. Three hours later I installed a new internal slave cylinder from NAPA and it started leaking immediately. Today the engine is coming out to put a GM slave cylinder. If you go with the internal slave, make sure to go OEM and not those cheap China S!@t. The motor is a 2000/2001 5.3L with a GTO intake.
Aruba1 is offline   Reply With Quote
