Old 08-09-2015, 09:01 PM   #1
hondo66
Relay Question
What are the 2 relays on engine side of firewall behind the hood hinge on drivers side? My 71 is a wiring nightmare everything is wire nutted together using red wire. The wires out of these relays are just cut off and wadded between firewall and inner fender.
The previous owner installed a cheap gauge set that doesn't work and I'm trying to get factory gauges working again.
hondo66 is offline   Reply With Quote
Old 08-09-2015, 09:28 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: Relay Question
Aftermarket ad on. Good luck.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 08-09-2015, 11:45 PM   #3
fat dan
Re: Relay Question
They may have been for the headlights, one for the high beam, and one for the low beam. Also could have been for fans or road, fog lights.
fat dan is offline   Reply With Quote
Old 08-10-2015, 09:08 AM   #4
Jason Banks
Jason Banks's Avatar
Re: Relay Question
Sounds like the Transmission Controlled Spark relay's
See this thread:
http://www.stovebolt.com/ubbthreads/...&Number=544501
Jason Banks is offline   Reply With Quote
Old 08-10-2015, 09:12 AM   #5
Jason Banks
Re: Relay Question
Here's another thread on this site:
http://67-72chevytrucks.com/vboard/s....php?p=7040140
Old 08-10-2015, 10:46 AM   #6
Davidf
Re: Relay Question
Yes, both relays on a '71 are for the Transmission Controlled Spark feature. The relays on my '71 are still bolted to the firewall, but long since abandoned in place as are most I would bet.
Davidf is offline   Reply With Quote
Old 08-10-2015, 09:57 PM   #7
hondo66
Re: Relay Question
Yeah that's them all right. Mine only have a brown wire hooked to the harness and they used the black for a ground to a switch under the dash.
Thanks for everyone's help.
